somethings not right..???plz hlp
Hi guys iam new to this..but i drive a 95 intgera and i crashed it a few yrs ago...i no not very smart..but ive jus goin it going again..and its not really running right i thought maybe it was the TPS sensor ssoo i changed it and adjusted it right..but..everytime i let go of the gas pedel the car shakes really bad like my engine n trany gonna fall out.. and has a very bad idle when cold...ive tryed alot of things iam opened to n e thing.this is the last thing left on my car....plz hlp..thanks Ricky
yah..well i think i did...i got a volt meter and change the volts to around .35 and .45...but jus incase iam not doing it...rite...???? n e other advise?? b/c i wudn't think the TSP would shake the car as much as it does..or when you let go of the gas pedel (while driving) the car jerks?? thanks
well i recalibrate that seem to have fixed the rough idle...thanks..i just moved the TPS as high as it could go b/c i notice there was to much play in the throttle cable...well i jus moved the TSP as high as it could go and it seem to fix the problem..and then i just turned down the idle b/c it started idling high...well that problem is fix..i still have the jerking when i let go of the gas...while driving..but its not as bad as it was ssoo iam getting closer...i was told m.b it can be my O2 sensor??? but i dout it.????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RHD DB8 »</TD></TR><TR><TD CLASS="quote">check your motor mounts, might be bad mounts causing vibrations you wouldn't feel normally.</TD></TR></TABLE>
Did you do this yet? A faulty motor mounts can cause shaking.
BTW...its .5 and idle and 4.5 at wot
no its not motor mounts....this isn't jus a small shaking while driving..this thing shakes rough...when you let go of the gas...sso i pretty sure its not mounts..or it wud be shaking all the time...
one more question for ya about mounts...did you check the torque mount and ac bracket mount? They are underneath the car...so they often get overlooked. A faulty torque mount and ac bracket mount will have this affect. After you let off the gas...the motor seem to want to pull back and forth.
thanks as i am new to this........ i dun really know....where that is ???? but i duno what the AC? mount would do with this problem...but yes the engine is shaking back and fourth...?? so i will chek that out thanks
also make sure the bolts are tight on the mounts i had a friend who had the exact same prob his bolts were only hand tightened and after 3-4 passes at the track bitch started shaking like it was in a rap video doing the harlem shake
good luck
good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProJectCvic »</TD></TR><TR><TD CLASS="quote">one more question for ya about mounts...did you check the torque mount and ac bracket mount? They are underneath the car...so they often get overlooked. A faulty torque mount and ac bracket mount will have this affect. After you let off the gas...the motor seem to want to pull back and forth. </TD></TR></TABLE>
I was referring to those mounts aswell.
Projcivic99
Apr 14, 2009 07:03 PM
sleepyhamsterlx
Dec 4, 2003 07:35 PM
