d16z6 and d16y8 harness question - -
Old Dec 7, 2004 | 07:40 PM
crzyfool24's Avatar
Default d16z6 and d16y8 harness question - -
Will a harness from a Z6 fit onto a y8 motor or do I have to get a y8 harness? Thanks
Old Dec 7, 2004 | 07:50 PM
lohatch's Avatar
Default Re: d16z6 and d16y8 harness question - - (crzyfool24)
the injectors, alternator, and distributor plugs will be different. the Z6 also doesnt not have 2 O2sensor plugs and it doesnt have a plug for the crank position sensor. otherwise most things would work. it would be easier to have a Y8 one though.
Old Dec 8, 2004 | 07:56 AM
Lee_Delso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crzyfool24 &raquo;</TD></TR><TR><TD CLASS="quote">Will a harness from a Z6 fit onto a y8 motor or do I have to get a y8 harness? Thanks </TD></TR></TABLE>
Just use the z6, it'll work fine.
Old Dec 8, 2004 | 07:59 AM
lohatch's Avatar
Default Re: d16z6 and d16y8 harness question - - (Lee_Delso)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lee_Delso &raquo;</TD></TR><TR><TD CLASS="quote">
Just use the z6, it'll work fine.</TD></TR></TABLE>you will have to use the Z6 injectors, alternator and repin the dist plugs because i dont think the Z6 dist will work on the Y8 head. so it wont work fine.
Old Dec 8, 2004 | 08:10 AM
Lee_Delso's Avatar
Default Re: d16z6 and d16y8 harness question - - (lohatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch &raquo;</TD></TR><TR><TD CLASS="quote">you will have to use the Z6 injectors, alternator and repin the dist plugs because i dont think the Z6 dist will work on the Y8 head. so it wont work fine.</TD></TR></TABLE>
The distributor will work but the mounts won't line up so you have to make the hole bigger on the distributor to fit the screw in. I just did a 93 Del Sol Si and dropped in a d16y8 and it works fine with out any check light problems. But if you can get a d16y8 harness then that will be better.
Old Dec 8, 2004 | 05:22 PM
crzyfool24's Avatar
So is there any way I can make a z6 harness work for a y8?
91integraLSVTEC
Sep 14, 2007 01:02 PM
d1nki
Jun 26, 2006 12:44 PM
rasinhell
Jan 18, 2005 08:24 AM
Soulless
Jan 3, 2003 12:15 AM
