Removing ATTS... Radiator help please
Old Dec 7, 2004 | 06:51 PM
Shakes's Avatar
space cadet
Default Removing ATTS... Radiator help please
the ATTS unit has two pipes for cooling that go into the radiator at the bottom.
what can i use to plug those up? i am thinking some form of rubber cap and then hose clamp and some RTV, but please toss out some ideas.
also where can you get rubber caps like that? that could withstand that heat.
Old Dec 7, 2004 | 08:21 PM
Shakes's Avatar
space cadet
Default Re: Removing ATTS... Radiator help please (Shakes)
night crew bump
Old Dec 7, 2004 | 08:29 PM
Shakes's Avatar
space cadet
Default Re: Removing ATTS... Radiator help please (Chase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chase &raquo;</TD></TR><TR><TD CLASS="quote">Just get a hose and connect the two...just be sure to buy heater hose to withstand heat </TD></TR></TABLE>
man im a ****** idiot. thanks
Old Dec 8, 2004 | 02:41 AM
Sticky Tires's Avatar
* B A N N E D *
Doug, what's wrong with your ATTS?
Planning on getting a LSD?
j00 ricer!
Old Dec 8, 2004 | 04:48 AM
Shakes's Avatar
space cadet
Default Re: Removing ATTS... Radiator help please (STicky Tires)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STicky Tires &raquo;</TD></TR><TR><TD CLASS="quote">Doug, what's wrong with your ATTS?
j00 ricer! </TD></TR></TABLE>
j00 idiot, ive told you a hundred times. Base H22a4 with an H23 tranny.
Old Dec 8, 2004 | 04:55 AM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">
j00 idiot, ive told you a hundred times. Base H22a4 with an H23 tranny. </TD></TR></TABLE>
BS. you never told me, you must of told the 300 other friends you have.
H23 tranny has better gearing?
Old Dec 8, 2004 | 04:57 AM
Shakes's Avatar
space cadet
H23 tranny has better gearing? </TD></TR></TABLE>
longer gears, cheaper. this engine will remain "stock" while the other one gets built.
Old Dec 8, 2004 | 05:07 AM
* B A N N E D *
longer gears, cheaper. this engine will remain "stock" while the other one gets built.</TD></TR></TABLE>
BL Baller!
Make sure you build it better than James.
Old Dec 8, 2004 | 05:42 AM
Shakes's Avatar
space cadet
BL Baller!
Make sure you build it better than James. </TD></TR></TABLE>
that will be a little hard to do, but we may build along with eachother.
Old Dec 8, 2004 | 05:43 AM
* B A N N E D *
that will be a little hard to do, but we may build along with eachother. </TD></TR></TABLE>
Old Dec 8, 2004 | 05:45 AM
Shakes's Avatar
space cadet
dreaming of the lude being pulled by my 07 tacoma up to Laguna seca. just wait and see. it will be done.
Modified by Shakes at 10:07 AM 12/8/2004
Old Dec 8, 2004 | 06:03 AM
* B A N N E D *
I have faith in you.
ludesterS
Oct 26, 2007 04:51 PM
dumkopf
Feb 15, 2007 10:07 PM
g2turbo
Oct 9, 2006 12:06 PM
vegas36
Mar 13, 2006 09:19 AM
90crxzc
Dec 20, 2003 08:27 AM
