help D4 light blinks
Old Dec 7, 2004 | 06:37 PM
azn_accord06's Avatar
Default help D4 light blinks
my D4 light is blinking when i m driving. When i start my car, it juke when i shift to reverse(R), it will jukes twice. Honda didn't give me a very clear answer, they said i need to replace the wire and harness around my tranny. Basically they didn't explain ****. Another shop i go to, they said one of my sensor is short on the tranny. The 3rd shop i went to, they told me i need a new computer. Can someone tell me what's wrong??
Another problem, my key gets stuck sometimes, i have to restart the car, and shift gear to D4, then shift back to park, shut it down, then the key will come out. What is the problem ???
Old Dec 8, 2004 | 04:59 AM
JimBlake's Avatar
Default Re: help D4 light blinks (azn_accord06)
The tranny controller uses the D4 light like a 'check-tranny light'. Gotta read the stored error code. What year Accord? If it's OBD-2 go to parts store & have them read the code. Each place was guessing something different, but they'll all have to do the diagnosis to be sure.
The key sticking is your interlock switches at the shift lever. It's not supposed to let you take out the key unless it's in Park. Somehow the key cylinder doesn't 'know' it's in park...
Old Dec 8, 2004 | 05:49 AM
shadow_ridge's Avatar
Default Re: help D4 light blinks (JimBlake)
sounds like a bad sensor or even worst a short in the line, i doubt its the ecu
Old Dec 8, 2004 | 12:13 PM
it is a 98 coupe LX V6. And i had an ignition interlock recall done last year, is that what my car is not recognize the car is in park??
Old Dec 8, 2004 | 01:18 PM
JimBlake's Avatar
That sure sounds like the ignition interlock system...
Make sure you ask whether you're included in the extended warranty business for that tranny. There's some dealer-tech people on here that would know better than me.
Old Dec 8, 2004 | 02:24 PM
jwogen1's Avatar
on my 94, when my d4 was blinking it ended up being the solenoids...not very cheap either
Old Dec 8, 2004 | 08:28 PM
Default Re: help D4 light blinks (jwogen1)
wat is solenoids?? I believe the second shop i went to did tell me something about that
Old Dec 9, 2004 | 04:08 AM
JimBlake's Avatar
Go to AutoZone, let them plug in a code reader, have them tell you the error code number. Why should you (or we) guess about solenoids or harnesses or whatever other BS they're saying? Get the code number. Sometimes their explanation of the problem is silly, but come back here with the number.
Meanwhile, search for v6 auto tranny warranty extension. Or call the dealer & ask point-blank about it.
Wrork
Jan 2, 2019 07:53 PM
briepnieks
Oct 17, 2008 11:45 AM
NikeSBdrift180
Aug 16, 2008 11:08 AM
hydeehydee
Sep 5, 2005 09:23 AM
