anyone ever used toulene to increase octane number?
Old Dec 7, 2004 | 06:26 PM
BlissSkr's Avatar
Default anyone ever used toulene to increase octane number?
At work today one of our regular customers was telling me about using this stuff called toulene (not sure on the spelling) that you can purchase at hardware stores to boost the octane rating of gas. I was just wondering if anyones ever done this or heard of this? And if its safe or not ?
Old Dec 7, 2004 | 06:29 PM
hOndafienD 04's Avatar
never heard of it, and would not try it.
Old Dec 7, 2004 | 06:32 PM
JTCdudeman's Avatar
Master H Technician
Default Re: (hOndafienD 04)
I wouldnt just use toulene... Mix it with xylene which is a lubricant and all is well.. This is the best known octane booster. Its kinda expensive, but not that bad when you really think about it. Prepare to spend $8 a gallon! Ive used it before and would say its much more effective and clean than using your auto parts octane booster at a much better price!
Old Dec 7, 2004 | 06:39 PM
fastludeh22's Avatar
Default Re: (JTCdudeman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JTCdudeman &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt just use toulene... Mix it with xylene which is a lubricant and all is well.. This is the best known octane booster. Its kinda expensive, but not that bad when you really think about it. Prepare to spend $8 a gallon! Ive used it before and would say its much more effective and clean than using your auto parts octane booster at a much better price! </TD></TR></TABLE>
you live in ga, not far from me. just buy race gas. 4.20 a gallon 110 octane unleaded
but i have heard of it. there was a theard on it about a year ago, had a lot of info
Old Dec 7, 2004 | 07:02 PM
Blackhorse6's Avatar
Unless you have a higher compression ratio. Boosting your octane will do NOTHING for you but burn extra money!
Old Dec 7, 2004 | 07:18 PM
Nick M's Avatar
Default Re: (Blackhorse6)
I've used it many times in my WRX
Its about $36 here for 5 gallons.
Old Dec 7, 2004 | 07:23 PM
hows the affect?
Old Dec 7, 2004 | 07:56 PM
satan_srv's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">never heard of it, and would not try it.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 &raquo;</TD></TR><TR><TD CLASS="quote">hows the affect?</TD></TR></TABLE>
you certainly change your opinion fast....
Old Dec 7, 2004 | 07:58 PM
v4lu3s's Avatar
RTFM
i ahve used toluene and xylene. last time i did i filled up with what the pump said was 93 and it was really 87, so i dumped in a gallon or two of xylene to bring the octane up as fast as possible.
Old Dec 7, 2004 | 08:01 PM
Default Re: (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv &raquo;</TD></TR><TR><TD CLASS="quote">
you certainly change your opinion fast....</TD></TR></TABLE>
i was just wondering...didnt say i'd try it
Old Dec 7, 2004 | 08:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackhorse6 &raquo;</TD></TR><TR><TD CLASS="quote">Unless you have a higher compression ratio. Boosting your octane will do NOTHING for you but burn extra money!</TD></TR></TABLE>
or other mods needing it, which are major ones only. i was not thinking about his reason for asking, just answered...
but why do you want higher octane?
Old Dec 8, 2004 | 04:51 AM
Monkey Fing a Coconut's Avatar
Default Re: (fastludeh22)
go with xylene, 118 octane, to figure out the octane u will have, say 1 gal xylene and 9 gal 91 oct, .1*118 + .9*91 = 93.7 octane
when using xylene or toulene u should also add some atf as normal gas has some lube added to it, xylene and toulene are not lubricants and do have have any kinds of lube in them, i think its like 5oz atf to 1 gal xylene/toulene, search for xylene and theres a thread about it
Old Dec 8, 2004 | 08:34 AM
Elkins911's Avatar
Default Re: (v4lu3s)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s &raquo;</TD></TR><TR><TD CLASS="quote">i ahve used toluene and xylene. last time i did i filled up with what the pump said was 93 and it was really 87, so i dumped in a gallon or two of xylene to bring the octane up as fast as possible.
how in the world did you know it was 87?
Old Dec 8, 2004 | 09:47 AM
bomber's Avatar
So if you never heard of it...it HAS to suck.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlissSkr &raquo;</TD></TR><TR><TD CLASS="quote">At work today one of our regular customers was telling me about using this stuff called toulene (not sure on the spelling) that you can purchase at hardware stores to boost the octane rating of gas. I was just wondering if anyones ever done this or heard of this? And if its safe or not ?</TD></TR></TABLE>
There are a lot of threads in the archive about this, as well as some on the internet (hit up google). You will have trouble though because you are misspelling the name.
Try 'toluene' (although to be honest a lot of people spell it toulene so you might search both terms).
Here is a good link: http://www.elektro.com/~audi/audi/toluene.html
Btw, it is becoming hard(er) to buy this stuff in bulk as it is a chemical used in meth production.
Old Dec 8, 2004 | 02:33 PM
v4lu3s's Avatar
RTFM
Default Re: (Elkins911)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Elkins911 &raquo;</TD></TR><TR><TD CLASS="quote">how in the world did you know it was 87?</TD></TR></TABLE>
cause it sounded like the engine was about to blow as soon as i stepped on the gas, i was runing some advanced timing in my midrange, and once i put the gas in and got on it, it sounded like a can full of gravel. retarding my timing all teh way and mixing the Xylene in got it cleared up til i could run all teh gas down and put better gas in.
Old Dec 8, 2004 | 02:41 PM
aboh6leenz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bomber &raquo;</TD></TR><TR><TD CLASS="quote">Btw, it is becoming hard(er) to buy this stuff in bulk as it is a chemical used in meth production. </TD></TR></TABLE>
So just add meth into your gas tank j/p
You say add some kind of lubricant to it, what kind?
Old Dec 8, 2004 | 04:59 PM
H22edAccord's Avatar
Default Re: (aboh6leenz)
i tried it and also heard it was an good fuel system cleaner. Seem to work pretty good to me.
Old Dec 8, 2004 | 05:15 PM
DCFIVER's Avatar
Community Builder
Loved
Community Favorite
Default Re: (H22edAccord)
read about it in sport compact but never used it. You do not need high compresion pistons to yield a good result with higher octane gas,. The higher the octane rating the cleaner the gas and the more resistant it is to detonation. any compression ratio can benifit from this . But the higher compression cars will benefit more. High octane gas will burn more completely and allow a longer flame front than low rated gas,which tends to explode rather than burn.
Rajinazn06
Oct 28, 2007 07:41 AM
pnut1.8c1
117
Apr 23, 2007 10:27 AM
-Championship-
Jul 12, 2006 07:23 PM
CivicEJ1
Dec 16, 2004 09:05 PM
motocross 04
Oct 19, 2004 06:02 PM
