Hasport ZC into EF Si Subharness?
Old Dec 7, 2004 | 06:21 PM
Sharpview's Avatar
Default Hasport ZC into EF Si Subharness?
where in the hell does this subharness go?
. . . this is supposed to make something easy but the only modification to the Si harness for the ZC is the cyp sensor and this harness does not achieve that like i thought it would. . . . can anyone tell me where this thing plugs in?
http://hasport.com/store/produ...id=86
Old Dec 7, 2004 | 06:39 PM
Sho Pow's Avatar
Default Re: Hasport ZC into EF Si Subharness? (Sharpview)
Im not sure but when I installed my zc the only difference in wiring was the dizzy plugs. It might be a conversion harness so you dont have to repin either your dizzy or you harness.
Old Dec 8, 2004 | 04:21 AM
Sharpview's Avatar
Default Re: Hasport ZC into EF Si Subharness? (Sho Pow)
yep and that is exactly why I bought it. . . .
but it doesnt even come close to plugging into the dizzy plug.
Old Dec 8, 2004 | 05:17 AM
QUiKSR20's Avatar
What year ZC?
Old Dec 8, 2004 | 05:35 AM
Sharpview's Avatar
Default Re: Hasport ZC into EF Si Subharness? (QUiKSR20)
not sure will have to look at the motor when i get home . . . why?
Old Dec 8, 2004 | 05:47 AM
QUiKSR20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sharpview &raquo;</TD></TR><TR><TD CLASS="quote">not sure will have to look at the motor when i get home . . . why?</TD></TR></TABLE>
There is diff ZC's DOHC SOHC Browntop Blacktop etc... Usually they are a plug in play affair.
Old Dec 8, 2004 | 06:01 AM
Sharpview's Avatar
ohhhh no this is a black top jdm ZC motor
ran fine in a previous EF si hatch then put it in a crx si and didnt feel like repinning the dizzy plug so i bought this subharness that i thought would allow it to be a "plug and play" . . . wronnggggg . . . i will call hasport today this thing makes no sense.
Old Dec 8, 2004 | 06:07 AM
QUiKSR20's Avatar
Gotcha.. Got me.. Tried to help Good luck Let us know how you make out
Old Dec 8, 2004 | 09:29 AM
Sharpview's Avatar
well just called hasport and they said it plugs into the dizzy, .. . . i think im going crazy
Old Dec 8, 2004 | 09:53 AM
Rywire's Avatar
On a dohc zc the cps wires are not on the main distributor. You have to lengthen the cps wires, and that hasport harness is just a 2 prong male plug with wires on it. Huge gimmick, just get one from a junk yard from basically any honda.
PS, with that harness you still have to solder. Its just stupid in my opinion.
Ryan
Old Dec 8, 2004 | 10:05 AM
JapJunkie's Avatar
Default Re: Hasport ZC into EF Si Subharness? (droppedcrxsi)
yUp my buddy bought the Hasport Subharness for his B16 swap in his rex. Its the same amount of work if you didnt have it! Its a waste of money and pointless.
Old Dec 8, 2004 | 11:37 AM
Rywire's Avatar
Default Re: Hasport ZC into EF Si Subharness? (JapJunkie)
The harness that you are talking about is different.
This is the zc only one
Ryan
jcivic33
Sep 3, 2006 08:49 AM
The Destroyer
11
Dec 30, 2005 02:22 PM
SC-MK1
May 22, 2005 08:51 PM
vtec_head
May 8, 2002 08:59 AM
