running 195/60/15 tires w/o rubbing on a 4th gen?
Old Dec 7, 2004 | 05:45 PM
eluder33's Avatar
Default running 195/60/15 tires w/o rubbing on a 4th gen?
I came by a great deal on a set of winter studded tires but they are 195/60/15. My existing tires are 205/55/15 will the 195 tires rub due to them being a 60 series tire? My car has lowering springs and sits about an inch to an inch and a half lower than stock. The previous owner of the tires ran them on a prelude and didn't have any problems, but his car wasn't as low as mine.
they are Cooper weathermaster tires with the studs, and I can get both for $70, yay or nay? I'm thinking the narrower width will help cut through the snow and the little bit of extra height will keep my lip safe
Old Dec 7, 2004 | 06:17 PM
BlissSkr's Avatar
Default Re: running 195/60/15 tires w/o rubbing on a 4th gen? (matty c)
You'll be fine i have an 1 1/2 inch drop all the way around and i run 195/60r15 snows with no rubbing at all, and they do help in the snow my lude was extremely hard to drive in the snow with the 205/55r15s but with the 195/60r15 its much better. But you should not just put two snows on the car you should have them in all four positions especially if they're studded. I work in a tire shop so I have some knowledge in this area
Old Dec 7, 2004 | 06:19 PM
Prolink's Avatar
Overall difference in hieght is .16" you should be fine.
Old Jun 9, 2006 | 07:32 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: running 195/60/15 tires w/o rubbing on a 4th gen? (Prolink)
with a 2.25front and 2.0rear drop would someone be fine with 195/60/15s?
Old Jun 9, 2006 | 08:41 PM
Silver Surfer's Avatar
if you can run the stock size, then there is no reason why you can't run 195/60/15
it's pretty much the same height with less width
Old Jun 9, 2006 | 09:44 PM
beqa16v's Avatar
Default Re: (Silver Surfer)
^ what he said.
4th gens can take 225/45/17x8 even droped. my buddy has it on his H23 (dont know how much his car is droped though) because of preludes double wishbone suspension, the rear wheels change angle and dive into the fender not touching it. so youll be fine 100%
Old Jun 10, 2006 | 07:20 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: (beqa16v)
i messed up, change that to 195/65/15...
Old Jun 10, 2006 | 07:49 AM
beqa16v's Avatar
Default Re: (AnthonyG2003)
it will be fine
Johnoolo
Dec 1, 2013 09:13 AM
VR4ownzU
Dec 22, 2008 01:50 PM
TSAngry
Jun 26, 2005 09:16 AM
ScottEK
Mar 4, 2004 09:46 PM
p0pe
Aug 16, 2003 01:34 AM
