Rsx Suspension help
Old Dec 7, 2004 | 03:51 PM
bloxp1vtec19's Avatar
Default Rsx Suspension help
I took off everybolt off from the front shocks and is hanging from something, looks like something that has to do with the steering, it wont pop out or any thing. n e tips on taking it out. sorry if i didnt explain it that well. thankz
Old Dec 7, 2004 | 04:54 PM
DC5ITR329's Avatar
Default Re: Rsx Suspension help (Jg303Ls)
You need a pulley to take that one off and it is part of the steering.
Old Dec 8, 2004 | 08:37 AM
kseriesDC5's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jg303Ls &raquo;</TD></TR><TR><TD CLASS="quote">I took off everybolt off from the front shocks and is hanging from something, looks like something that has to do with the steering, it wont pop out or any thing. n e tips on taking it out. sorry if i didnt explain it that well. thankz</TD></TR></TABLE>
The tierod? does it have a joint? if so i used a joint breaker tool
Old Dec 8, 2004 | 10:27 AM
whiteDCfiver's Avatar
Default Re: Rsx Suspension help (kseriesDC5)
Theres 3 bolts, 17 or 14 mil i cant remember on the top. Should be easy theyre only torqued at 33ft lb. You need to pop your hood and theyre right there. Once your wheel is off there are 2 main bolts holding it in against the hub. These are the hard one torqued at like 70 ft lb. There are also 2 other little bolts holding something, cant remember what exactly. But there plain as day. All the bolts are amber colored so its easy to see among all the black. Then you need to pop the ball joint holding the tie rod end.
If you use a hammer be careful. I rented a ball joint remover from Kragen. It was a deposit of a 100 bucks but you get the whole thing back as soon as you bring the tool back. Goodluck bro
Old Dec 8, 2004 | 07:05 PM
thankz you guys
teggsr925
Oct 1, 2006 08:55 PM
eymnewdc4
Jul 12, 2005 04:48 PM
93HONDAACCLUDE
Aug 21, 2004 08:00 PM
HapaHaole
Acura TSX
13
Nov 11, 2003 01:19 PM
BlackThorN
10
Aug 1, 2003 02:06 AM
