NEED HELP ASAP 92 VX never starts in the rain!!! NEED HELP ASAP SUPPOSED TO PICK UP A DATE!!!
Old Dec 7, 2004 | 01:39 PM
MONTCO Si's Avatar
Default NEED HELP ASAP 92 VX never starts in the rain!!! NEED HELP ASAP SUPPOSED TO PICK UP A DATE!!!
It seems like evertime my car has sat in the rain it doesnt want to start. Ive been told its possibly the main relay because moisture gets in between the sauder and causes a disturbance not allowing the fuel pump to prime itself. could this be true? i need help ASAP because im supposed to be out on the road picking up a date!
Old Dec 7, 2004 | 01:45 PM
_Spugen_'s Avatar
Is she hot???
Old Dec 7, 2004 | 01:46 PM
dmxsoulja3's Avatar
Default Re: (SpugenEG)
moisture in the dizzy cap? My car completely died because of this, would have never thought..
Old Dec 7, 2004 | 01:52 PM
sohcvtec1995's Avatar
Default Re: NEED HELP ASAP 92 VX never starts in the rain!!! NEED HELP ASAP SUPPOSED TO PICK UP A DATE!!! (M
You might want to borrow a friends car, cause it would not be cool if your car did not start on your date
Old Dec 7, 2004 | 01:55 PM
MONTCO Si's Avatar
once she gets started she is fine unless its raining really hard and i go thru a big puddle which happened once...the car just totally stalled out on me and i pushed it in a parking garage left it there for a half a hour and it was fine...the puddle wasnt that big but i guess it was big enuff to make my car stall...so much for this car being a daily driver
Old Dec 7, 2004 | 02:34 PM
jlacoy82's Avatar
71.192.16.183
Do you have a CAI by any chance?
Old Dec 7, 2004 | 02:56 PM
Unsivil_audio's Avatar
Take note next time it wont start in the rain, listen when you click your key foward (just to the on position, not start) for the fuel pump kicking on. If it does than the problem is not your main relay. Also remember your three basics, Fuel + Spark + Air = a running motor. If you hear the fuel pump pull your plugs and have some crank it while you check for spark. If no spark you have something wrong with your ingnition system, I'd prolly check all the spark plugs to make sure it wasnt just a couple that werent getting spark. Then I'd check the distributor for moisture, or just switch it out with a friends.
Old Dec 7, 2004 | 03:13 PM
97LxCivicVtec's Avatar
moisture in the distributer....gotta be
Old Dec 7, 2004 | 08:35 PM
89 pos's Avatar
i will take her for you
Old Dec 7, 2004 | 09:02 PM
RedlinedVTEC's Avatar
Could be moisture getting in down by the ecu causing problems. There was a service bulletin about water getting in in the passanger kick panel area.
Old Dec 7, 2004 | 09:07 PM
NineTwoSi's Avatar
That's what i'm thinkin'... Especially if going through big puddles causes the car to bog or die. The seal on the dist. cap could be bad.
Old Dec 8, 2004 | 03:46 AM
MassScene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedlinedVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Could be moisture getting in down by the ecu causing problems. There was a service bulletin about water getting in in the passanger kick panel area.</TD></TR></TABLE>where did you hear this??? how do we fix it???????????? I cant figure out where the goddamn water is comin from!!!!!!!!!!!!!!!!!!
Old Dec 8, 2004 | 05:14 AM
aznphantoms's Avatar
pull off the dizzy cap and look for signs of moisture or rust I would put money on it. though never hearing of it out of hondas i know dodge had a problem with it.
Old Dec 8, 2004 | 05:34 AM
_Cyclone_'s Avatar
Default Re: (aznphantoms)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznphantoms &raquo;</TD></TR><TR><TD CLASS="quote">pull off the dizzy cap and look for signs of moisture or rust I would put money on it. though never hearing of it out of hondas i know dodge had a problem with it.</TD></TR></TABLE>
...unless the rubber seal/gasket around the dizzy cap is missing. I bought a cheap *** cap for my integra and didn't notice it had no gasket. Exact same symptoms as you bud. I put that gasket in (******* $9 from the dealership... ) and never had a problem in the rain again.
Old Dec 8, 2004 | 08:11 AM
MONTCO Si's Avatar
Default Re: (Unsivil_audio)
when i turn the car in the on position i can hear the fuel pump prime itself. so i guess its not the fuel pump...when i try and get the car it cranks it just sounds like its not getting a spark. im going to replace the spark plugs today and check out whats going on with the distributor and see if there is any moisture in there...and no i do not have a CAI...the car is totally stock. im going to have to figure out this problem sooner or later because when winter comes its going to suck i dont wana have to be hoping a ride or riding my track car around in the winter.
Burton7706
Jan 3, 2007 07:39 AM
Rudelude22
Feb 6, 2006 05:27 PM
yellowbuffalo
Jul 13, 2002 02:15 PM
