Help with Physics project (60mph - 0mph stopping distance)
Old Dec 7, 2004 | 01:38 PM
EH3Kid85's Avatar
Default Help with Physics project (60mph - 0mph stopping distance)
Well, I fucked up and i'm not able to do my Physics project in time for it's due-date, so i'm bullshitting it. My intention was to test aftermarket brake rotors vs. stock and see if the stopping distance changed significantly. All I need to know is if someone could tell me what (on average) the stopping distance was for an EG Civic Si. From 60mph to 0mph, how far did it take to come to a complete stop, is what i mean. I'm just gonna take that number and divide it in half, 'cause I was gonna do 30 - 0mph for safety reasons. I'd really appreciate the help, or even a link if you have one. I found the stopping distance for an EK using the search, but not an EG.
Old Dec 7, 2004 | 01:48 PM
Marauder's Avatar
Default Re: Help with Physics project (EH3Kid85)
Don't know why you would do it on brake rotors, as they don't affect stopping distance, only thing they do is dissipate the heat from braking and slots also prevent pads from glazing.
Old Dec 7, 2004 | 01:56 PM
EH3Kid85's Avatar
Default Re: Help with Physics project (Marauder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">Don't know why you would do it on brake rotors, as they don't affect stopping distance, only thing they do is dissipate the heat from braking and slots also prevent pads from glazing. </TD></TR></TABLE>
Sssshhh! My physics teacher doesn't know that...
Old Dec 7, 2004 | 02:00 PM
snoochtodanooch's Avatar
i'd have to say your fucked
i agree with marauder in saying that the rotors won't have nearly the effect that pads will have. You should just make up a bunch of falsified data and say how through your research you learned that pads affect breaking distance more than rotors. yaddayaddayadda, remember it is always the effort that counts, not whether or not you were right.
Old Dec 7, 2004 | 02:04 PM
EH3Kid85's Avatar
Default Re: Help with Physics project (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">i'd have to say your fucked
Why am I fucked? It's not like I have to prove rotors make a difference. It doesn't matter if my "hypothesis" is correct, just as long as I have the report and 'data'. My original intention was to test factory vs. aftermarket rotors, then for ***** and giggles test the new pads I got.
All I need is a number. 140ft, 150ft, I can't seem to find it anywhere
Old Dec 7, 2004 | 02:10 PM
Redline96LX's Avatar
* B A N N E D *
its not gonna be half the distance, itll be closer to like 1/3 or 1/4 of the distance, simple physics.
Old Dec 7, 2004 | 02:17 PM
duh blacksheep's Avatar
Default Re: Help with Physics project (Redline96LX)
just right in your analysis and conclusion that rotors didnt make a difference, so you didint need the test for distances...whats the big deal? =P
Old Dec 7, 2004 | 02:20 PM
EH3Kid85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline96LX &raquo;</TD></TR><TR><TD CLASS="quote">its not gonna be half the distance, itll be closer to like 1/3 or 1/4 of the distance, simple physics. </TD></TR></TABLE>
Thanks, that helps
Old Dec 7, 2004 | 02:24 PM
Marauder's Avatar
Default Re: Help with Physics project (duh blacksheep)
Well hows this...
Just change it up a little bit and say that standard rotors with glazed over pads stop worse than the same pads with slotted rotors. Since the slots keep the pad surface fresh.
I'd say the 30-0 mph braking distance is probably like 40 feet. Think you'll have a hard time finding it unless you do research for like car and driver magazine.
The four things that affect the brake system are:
1) line pressure
2) effective clamping radius
3) caliper piston area
4) friction coefficient (between rotor and pad)
Old Dec 7, 2004 | 02:38 PM
EH3Kid85's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Marauder &raquo;</TD></TR><TR><TD CLASS="quote">Well hows this...
1) line pressure
I tried searching car and driver's website, as well as road and track, though I didn't get anything on the Si other than the '99/00 and the EP3. The list of things that affect the brake system really help
Modified by EH3Kid85 at 7:29 PM 12/7/2004
Old Dec 7, 2004 | 04:19 PM
then just do it off of a 2000 or ep3, what does it matter, your bullshitting the evidence anyway?
Old Dec 7, 2004 | 04:32 PM
Frozen E's Avatar
H-T White Ops
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">then just do it off of a 2000 or ep3, what does it matter, your bullshitting the evidence anyway?</TD></TR></TABLE>
Or just bullshit the entire thing.
Old Dec 7, 2004 | 04:48 PM
EH3Kid85's Avatar
Maybe i'll just use the EK data I found. Not a huge difference between an EK hatch and an EG hatch.
Old Dec 7, 2004 | 05:49 PM
EH3Kid85's Avatar
w00t, report is done. 7 pages (minimum of 5), including graphs and a couple pictures.
Old Dec 7, 2004 | 07:48 PM
EH3Kid85's Avatar
Is 40 feet too short? Should I bump up that number a little? Remember, this is 30 - 0mph
poormans_typer69
Jan 11, 2008 03:24 PM
bigandy90
Oct 14, 2007 08:04 PM
G2_Fella
Mar 14, 2007 05:22 PM
badb18c1
Jun 20, 2005 04:04 AM
andrewasf77
Oct 24, 2003 09:52 AM
