tranny leaking at passenger side shaft entry
Old Dec 7, 2004 | 01:25 PM
pnltnc's Avatar
Default tranny leaking at passenger side shaft entry
Whats up, I have a 95 gsr hatchy. Looked under the car the other day to find the trans oil coming out were the shaft connects to the tranny. What seal do I need to get and does any body have tech pics?
Old Dec 7, 2004 | 01:33 PM
hybridls's Avatar
Default Re: tranny leaking at passenger side shaft entry (pnltnc)
what tranny are you runnin if it is a gsr you get a cv seal for a gsr
Old Dec 7, 2004 | 01:35 PM
Marauder's Avatar
Default Re: tranny leaking at passenger side shaft entry (hybridls)
https://honda-tech.com/zerothread?id=1074040
You're not the only one.
Old Dec 7, 2004 | 01:36 PM
pnltnc's Avatar
Default Re: tranny leaking at passenger side shaft entry (Marauder)
gsr trans.
Old Dec 7, 2004 | 01:38 PM
pnltnc's Avatar
I think the axle popped out a little.. Will probably have to pull it apart and check
Old Dec 7, 2004 | 01:51 PM
Marauder's Avatar
Like I said in the post I linked to, probably the axle seal in the trans.
seppuku's Avatar
jack up the vehicle and make sure the axle is fully seated...if it is then its your cv seal...they are easy to replace...you will have to remove the axle first.
bmxkills
Transmission & Drivetrain
Oct 29, 2010 09:15 AM
Historyg
Jan 19, 2008 09:24 AM
lilpastrana
Oct 19, 2007 07:03 PM
95DxSi-R2
Apr 25, 2006 07:11 PM
wreckedmyteg
Jul 20, 2004 07:40 AM
