92-95 Greddy turbo kit and 96-00 Greddy kit
Old Dec 7, 2004 | 12:25 PM
wheatfroggy17's Avatar
Default 92-95 Greddy turbo kit and 96-00 Greddy kit
I am 100 percent that I am getting a Greddy turbo kit for my 93 civic ex and I was wondering what kind of compatibility issues I would encounter by purchasing the 96-00 turbo kit. It comes with injectors and a slightly bigger trim turbo, but is there anything in the 96-00 kit that only works with the OBDII system and not the OBDI? Any help will be much appreciated.
Old Dec 7, 2004 | 12:26 PM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: 92-95 Greddy turbo kit and 96-00 Greddy kit (wheatfroggy17)
The Emanage is designed for OBD-II I believe, but I'm sure there's some diagram you could use to wire it for OBD-I. If I were you, I'd buy the 96-00 kit, sell the Emanage and RC 310s, and get Uberdata and RC 440's.
Old Dec 7, 2004 | 12:32 PM
p0gi's Avatar
Default Re: 92-95 Greddy turbo kit and 96-00 Greddy kit (boostincoupe)
The emanage is designed to work with a wide variety of cars, not just obd-2 vehicles. I have 2 emanages 1 on obd-2 and one on obd-1. Keep the emanage, its an excellent system and works well, and it comes with the kit. Getting larger injectors is a good thing too. I say go with the 96-00 kit, I dont think youll have any problems.
Old Dec 7, 2004 | 07:22 PM
Default Re: 92-95 Greddy turbo kit and 96-00 Greddy kit (p0gi)
So get the 96-00 kit because of the injectors? The emanage will work without modification to my 93 OBDI ecu? Thanks again for the help.
Old Dec 7, 2004 | 08:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wheatfroggy17 &raquo;</TD></TR><TR><TD CLASS="quote">So get the 96-00 kit because of the injectors? The emanage will work without modification to my 93 OBDI ecu? Thanks again for the help.</TD></TR></TABLE>
Get the 96-00 kit for the bigger turbo, that is all.
Old Dec 7, 2004 | 09:25 PM
p0gi's Avatar
yes the emanage will work without modification. The 96-00 kit has a better flowing turbo.
Old Dec 8, 2004 | 05:01 AM
96-00 kit it is. Thanks guys!!
Old Dec 8, 2004 | 05:05 AM
VisualAutoMotoring's Avatar
Just make sure when your wiring your Emanage that dont use the diagram it comes with. The skematics are for the OBD I P28. The OBDII P13(?) wiring placements are different. Use like a SAFC diagram to cross reference it.
Old Dec 8, 2004 | 02:27 PM
p0gi's Avatar
Default Re: 92-95 Greddy turbo kit and 96-00 Greddy kit (Hybrid-Performance.com)
you can find the emanage install manual at http://www.mohdparts.com/ just click on the emanage link
Old Dec 8, 2004 | 02:47 PM
SRT_Andy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostincoupe &raquo;</TD></TR><TR><TD CLASS="quote">
Get the 96-00 kit for the bigger turbo, that is all.</TD></TR></TABLE>
The turbos are actually the same, it's just the wheel that's different. Being a Greddy dealer, I'll tell right now the only difference between the two turbos are the base HP rating - 250 for the 15G and 300 for the 19T. If 50BHP is worth spending the extra $400, then have at it. Realistically, you can have a 15G kit and a larger set of RC injectors for less than the 19T kit. Both kits now come with the E-Manage and aluminum piping.
Old Dec 8, 2004 | 04:48 PM
Default Re: 92-95 Greddy turbo kit and 96-00 Greddy kit (SRT_Andy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SRT_Andy &raquo;</TD></TR><TR><TD CLASS="quote">
The turbos are actually the same, it's just the wheel that's different. Being a Greddy dealer, I'll tell right now the only difference between the two turbos are the base HP rating - 250 for the 15G and 300 for the 19T. If 50BHP is worth spending the extra $400, then have at it. Realistically, you can have a 15G kit and a larger set of RC injectors for less than the 19T kit. Both kits now come with the E-Manage and aluminum piping.</TD></TR></TABLE>
I have a 15G kit, and I'm loking to get the 19T in the future most likely. That being, because I'm looking to hit 300whp and the 15G just isn't going to do it.
Do you have access to more info. on the 15G vs. 19T comparison? I'd like to read it.
teezlr
Aug 15, 2010 10:46 PM
willyboyK20
Apr 24, 2004 01:33 PM
eg686
Sep 30, 2003 08:36 PM
Racerage1
19
Sep 21, 2003 02:48 PM
