all IACV interchangable?
Old Dec 7, 2004 | 10:55 AM
Honda Sport's Avatar
Default all IACV interchangable?
are all IACV interchangable between, b-series, h, d, and f series? if not, which ones are interchangable? TIA
Old Dec 7, 2004 | 07:13 PM
mmuller's Avatar
Mad Scientist
Default Re: all IACV interchangable? (Honda Sport)
they all dont have the same bolt pattern, but will work if you only use 1 bolt to hold it in place
Old Dec 7, 2004 | 07:16 PM
I'm tryin to help somebody out. looks like he might need a new IACV but wants to make sure that's the problem before he buys a new one. I can swap mines with his but wasn't sure that it would work. so you're telling me it should work even if I just bolt up 1 bolt?
by the way, I have a JDM h22a and he has a JDM b16 1st gen.
Old Dec 7, 2004 | 08:09 PM
v4lu3s's Avatar
RTFM
i am using a d series iacv on an h series manifold without issues.
Old Dec 8, 2004 | 12:15 AM
Sack Master's Avatar
Default Re: (v4lu3s)
The ones Ive have 2 different sizes. Some manifolds are tapped for both bolt patterns though.
Old Dec 8, 2004 | 01:29 PM
another question, how did you tell your IACV were bad? what symptoms were you guys having?
Old Dec 8, 2004 | 02:20 PM
PrettyLude's Avatar
bad idling, constant surging
Old Dec 8, 2004 | 02:54 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: (PrettyLude)
constant surging could also be fast idle valve you have to be careful because they have the same symptoms.....
Old Dec 8, 2004 | 03:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">bad idling, constant surging</TD></TR></TABLE>
can you elaborate a lil more? fluctuation in idle? from what rpm to what rpm? surging when at idle? what was your idle sitting at?
Old Dec 9, 2004 | 09:46 AM
SiBuddy00's Avatar
i'd like to knwo this too, did a mini me on my friends car and we're having iacv issues
Old Dec 9, 2004 | 10:28 AM
n1div's Avatar
Default Re: (Honda Sport)
Fluctuation in idle can also be other things as well:
Vacuum leak
Improper idle adjustment
Poorly tuned ecu map
Air in coolant lines
Just to name a few...
Graffit
Jul 24, 2017 12:10 AM
Jap_Spec_Imports
Oct 6, 2008 12:03 PM
97_coupe
Jul 8, 2008 10:05 AM
Thepanda
Mar 31, 2008 10:26 AM
CrXstEalin
Jan 20, 2004 06:55 PM
