Type S Piston Part # ?
http://cgi.ebay.com/ebaymotors...=WD1V
220 for the set brand new.
This place has great prices.
http://www.hmotorsonline.com/s...10026
wow guys.....ebay and hmotors arent honda.....
i just figured i would say that....and i know people on here have the #, i have seen it before and cant find it....try the search again with "type s piston type A" or something, the type A is the standard bore, the B is .025 over....search for A or B dependent on which you want of course....
incorrect, B is the smallest std size
A is the largest std size, i think its something like .009 (correct me if im wrong) bigger than B std size.
oversize is .025 bigger in size
there are officially 3 different size pistons, std B , std A, and oversize .025
13010-P5P-J00 type-s A bore
13020-P5P-J00 type-s B bore
13030-P5P-J00 type-s OS 0.25
i have a set of A bores that go right down the bores on BOTH my B bore blocks. but i dont thnk that matters since piston to wall clearance is too tight!
Modified by v4lu3s at 9:46 AM 12/8/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq »</TD></TR><TR><TD CLASS="quote">It's faqued
https://honda-tech.com/zerothread?id=894282</TD></TR></TABLE>
my bad, thanks
also, where do u guys go to order these??? do u know of certain honda dealers that will order jdm only parts???
my bad, thanks
That's not true at all...
There are two ways:
1) On the block is a stamp, that indicates the pistons installed at the factory:
"AAAA" "ABAA" "BBBB" etc.
2) On each piston that is not an A piston, there is a mark in the center of the piston. If you take out the spark plugs, and look into the hole with a bright light... you can see if you have B pistons.
I had thought the A pistons were the standard pistons and B pistons were in case of casting / machining issues.
It's good to know that the block I have can be lightly honed and have an A piston put in #4 / #1... or hone-honed and have an OS piston installed.
Neato.
There are two ways:
Neato.
