An oil pump is an oil pump is an oil pump?
Old Dec 7, 2004 | 08:24 AM
URNVS's Avatar
Default An oil pump is an oil pump is an oil pump?
I am rebuilding the bottom end of my B16 for high boost applications. While everything is appart I want to replace the oil pump but was wondering if there are pumps available that are better/more reliable than others?
Old Dec 7, 2004 | 09:48 AM
PrettyLude's Avatar
https://honda-tech.com/zerothread?id=1073092
Old Dec 7, 2004 | 07:11 PM
mmuller's Avatar
Mad Scientist
Default Re: An oil pump is an oil pump is an oil pump? (URNVS)
stock is fine
Old Dec 8, 2004 | 08:40 AM
URNVS's Avatar
Default Re: (PrettyLude)
Thanks for the info! One more question, does anyone know for sure if the B16 & B18 (all b-series) pumps are the same?
Old Dec 8, 2004 | 08:50 AM
Kataku2K3's Avatar
Default Re: (URNVS)
As I've mentioned before all the late model stuff run the same diameter gear but the spring/pressure rate may be different (not sure on that). If you want to be safe just buy yourself a new GSR/ITR pump.
94siturbo
Nov 2, 2003 03:16 PM
USDM 4G VTEC
Sep 9, 2003 01:19 AM
