zc dohc (non v-tec) swap in 93 coupe :)... need help though!!!!!!!!!!!
Old Dec 7, 2004 | 08:14 AM
heyzeus2003's Avatar
Default zc dohc (non v-tec) swap in 93 coupe :)... need help though!!!!!!!!!!!
we did the swap as smoothly as possible for a backyard job ... we started the car up and everything, but the car does not seem to be running so great, so we tested the ecu and got 2 codes 5(MAP sensor) & 10 (IAT sensor)... we fixed the MAP sensor code (easy fix), but we have no clue on where or how to fix the IAT sensor!!!!!!!! HELP!!!!
again the engine is a 3rd gen DOHC ZC (non v-tec) engine, any help is greatly appreciated, thanx in advance
Old Dec 7, 2004 | 09:10 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: zc dohc (non v-tec) swap in 93 coupe :)... need help though!!!!!!!!!!! (heyzeus2003)
Get a new IAT sensor. It goes somewhere in the intake manifold,most of them or on the back(small white 2 wire sensor). Good luck
Old Dec 7, 2004 | 09:15 AM
Average Al's Avatar
which ecu are u using
IAT is pluged into IM
intake air temperture
Old Dec 7, 2004 | 10:22 AM
Default Re: (Average Al)
its my friends car... he said he's using a chipped P75 (OBDI) ECU with a 94 ex engine harness (so there are some plugs that are and aren't being used), any ideas on where exactly the IAT sensor might be located or how to fix the problem, also if it helps you help us out, right now we are just starting the car with out the exhaust (headers only), could this be a problem?
Old Dec 7, 2004 | 11:51 AM
bump
Syke909
Oct 4, 2013 05:23 PM
ArmedFelon99
Oct 17, 2009 03:36 PM
~sp33~
10
Mar 3, 2008 02:28 PM
heyzeus2003
Feb 8, 2005 07:58 AM
pelotudo
Aug 23, 2002 08:54 PM
