how much should a shop charge to put together an lsvtec
Old Dec 7, 2004 | 07:55 AM
EFMAN's Avatar
Default how much should a shop charge to put together an lsvtec
how much should a shop charge to put together an lsvtec not parts just to do the labor?
Old Dec 7, 2004 | 02:01 PM
EFMAN's Avatar
Default Re: how much should a shop charge to put together an lsvtec (EFMAN)
Old Dec 7, 2004 | 03:51 PM
pb16b's Avatar
specify. is it just to put the head on the block?
Old Dec 7, 2004 | 03:55 PM
hayabusa160's Avatar
Default Re: how much should a shop charge to put together an lsvtec (pb16b)
assemble the motor is maybe like 500-700 around there depends where u take it too
Old Dec 7, 2004 | 03:59 PM
drdisco69's Avatar
Default Re: how much should a shop charge to put together an lsvtec (hayabusa160)
Damn, I'll do your motors! $500 is a lot to assemble a motor. I'm getting my hype r motor put together by a shop, with honing and measuring everything, it's $180. Thats just the bottom end, but still, bolting a head on will be nothing.
Old Dec 7, 2004 | 04:10 PM
Default Re: how much should a shop charge to put together an lsvtec (drdisco69)
damn 180? thats cheap. i was just lookin at my invoice to assemble a motor it was around 500
Old Dec 7, 2004 | 04:41 PM
drdisco69's Avatar
I guess I get the dealer hookup. I'm using all Honda stuff, too, no weird things to try and fit.
Old Dec 7, 2004 | 06:57 PM
boosted k20's Avatar
500-700 sounds about right to have someone who knows what there do n to put a Vtec head on an LS block.
Old Jan 25, 2005 | 01:17 AM
Hapexamendios EJ8's Avatar
Default Re: how much should a shop charge to put together an lsvtec (boosted k20)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted k20 &raquo;</TD></TR><TR><TD CLASS="quote">500-700 sounds about right to have someone who knows what there do n to put a Vtec head on an LS block.</TD></TR></TABLE> thats insane
Old Jan 27, 2005 | 09:47 PM
pinoyrukus's Avatar
Default Re: how much should a shop charge to put together an lsvtec (Hapexamendios EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hapexamendios EJ8 &raquo;</TD></TR><TR><TD CLASS="quote"> thats insane
hell yah thats insane. Just buy a manual and do that **** youself, or get a friend who knows what the hell they doing. You could use that 500-700 towards more stuff for you car. just my 2 cents
Old Jan 27, 2005 | 09:51 PM
b16h22a's Avatar
do it yourself and save the money it is not hard to do and doesent take that long either
Old Jan 28, 2005 | 04:49 AM
DIFFUT'S INC.'s Avatar
Default Re: (b16h22a)
we charge $600 for a full put together. Everything such as puttin piston , cam, check valves clearness make sure its not hittin anything .Everything. All you have to do is put it in and check the timming and your good to go ill would charge you about 200-250 thats plug the hole on the head make the pins bigger re TQ it with a new head gasket and run the oil line
Old Jan 30, 2005 | 04:52 AM
civic-4-ges's Avatar
Default Re: (DIFFUT'S INC.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIFFUT’S INC. &raquo;</TD></TR><TR><TD CLASS="quote">we charge $600 for a full put together. Everything such as puttin piston , cam, check valves clearness make sure its not hittin anything .Everything. All you have to do is put it in and check the timming and your good to go ill would charge you about 200-250 thats plug the hole on the head make the pins bigger re TQ it with a new head gasket and run the oil line </TD></TR></TABLE>
Thats because you know what you are doing. Most average shops have no clue how to get things done correctly when you mis-match components from different engine models, only because of the reference material they have on hand.
Old Mar 29, 2005 | 08:23 PM
importrracer's Avatar
my friend is a certified mechanic on imports and does lsvtec swaps all day long. i am assisting him right now since i kind of know my stuff and he is charging me $300. that includes installing 20 over bore wiesco pistons ,eagle rods,block guard, waterpump,oil pump,vtec oil l;ine feed including drilling and tapping, bolting the head on , installing it in my EG , and wiring for vtec
Old Mar 29, 2005 | 08:32 PM
k00lt1nt's Avatar
damn...5-700... i did my own b20/vtec....ill do it for u for 400
LOWPRO!!!
90datech
Jun 3, 2007 02:22 PM
mtownsi
29
May 8, 2007 10:06 AM
mcvive
Jun 22, 2006 08:53 PM
BlueShadow
Welding / Fabrication
Aug 6, 2005 08:00 PM
