grinding/chatter
Old Dec 7, 2004 | 07:28 AM
beef1020's Avatar
Default grinding/chatter
94 civic dx;
syptoms: first, this happens in all gears when clutch is engaged. Second, it happens only for a range in upper RPMs but as i do not have a tach i don't know the RPMs. Ex, in 5th gear no noise untill about 70-75, then slight chatter, then from 80 up no noise. Thanks for your input.
Old Dec 7, 2004 | 08:24 AM
beef1020's Avatar
Default Re: grinding/chatter (beef1020)
bump, thanks again
Old Dec 7, 2004 | 09:12 AM
2fast4u831's Avatar
I'm really 2slow
I think you need a new throw out bearing.
Old Dec 7, 2004 | 09:40 AM
beef1020's Avatar
Default Re: (2FAST4U831)
i searched and came up with this
"you know your throwout bearing is bad when you hear a faint grinding sound as you push the clutch in (down) and it goes away when you release."
I do not have this syptom???
Hmotoredcoupe
Transmission & Drivetrain
10
May 27, 2015 07:27 PM
cred1983
Jun 18, 2013 10:52 AM
zrs6v4
Jun 9, 2013 12:01 AM
Tking10
Sep 1, 2011 11:00 AM
Toadfart
Jan 13, 2004 08:16 PM
