Blower motor just crapped out..help before I freeze my a$$ off !!!!
Old Dec 7, 2004 | 06:34 AM
MikeTV
Guest
Posts: n/a
Default Blower motor just crapped out..help before I freeze my a$$ off !!!!
3 days ago my heater/blower fan just stopped working. Its like 40 degrees here in CT and I need to fix it fast. I was wondering if you guys knew whether the actuall motor needs replacing, or just the resistor ? Also, can I remove the heater motor without removing the dash ?
Lastly, are the blower motor/resistor from a 92-95 civic the same as the ones from a DC2 ?
Modified by Eclipse spanker at 3:46 PM 12/7/2004
Old Dec 7, 2004 | 08:08 AM
FragSyndrome's Avatar
Default Re: Blower motor just crapped out..help before I freeze my a$$ off !!!! (Eclipse spanker)
well I don't know if the actual unit is to blame, but if it is, I have one for sale! Let me know if you're interested.
Old Dec 7, 2004 | 10:54 AM
Mazinger's Avatar
Default Re: Blower motor just crapped out..help before I freeze my a$$ off !!!! (FragSyndrome)
You can reach it under the dash.
Old Dec 7, 2004 | 05:01 PM
kikwear002's Avatar
somebody help this guy i drove in with no heat in florida and i was cold enough and it was only 50 out.
Old Dec 7, 2004 | 05:59 PM
Danziver's Avatar
My blower went out and i thought it was the resistor b/c the different fan speed settings would not work. I replaced the resistor and the blower, it was a really quick fix about 30 min. Contact me if you need any details.
Old Dec 8, 2004 | 06:57 AM
MikeTV
Guest
Posts: n/a
Default Re: Blower motor just crapped out..help before I freeze my a$$ off !!!! (Danziver)
ok guys thanks alot for all of your replies ...This morning I pulled the blower motor, eyeballed it a little to see if something was visually wrong, and then put it back in.....and it worked ! how random is that !! I sitting here scratching my head trying to figure out why it wouldn't work, and then work all of a sudden without me even doing anything to it....but whatever, at least I wont have icicles hanging off my nuts when I get home from work.....thanks guys
Old Dec 9, 2004 | 05:52 PM
punkybrewster's Avatar
glad everything worked out for you... geez who would want icicles hanging off there nuts
Old Dec 9, 2004 | 06:12 PM
jdmotorsports's Avatar
might just of been a bad connection. glad to see it resolved its self.
Old Dec 10, 2004 | 06:14 AM
Mazinger's Avatar
This was happening on my 94LS. The motor would slow down or die. I would pull it out and manually turn it. After putting it back in, it would be fine. It would die every couple of days.
Old Dec 11, 2004 | 06:43 AM
MikeTV
Guest
Posts: n/a
Default Re: Blower motor just crapped out..help before I freeze my a$$ off !!!! (Mazinger)
thats so weird....i wonder if that means the connector on the harness is f*cked...........
Old Dec 23, 2004 | 09:24 PM
VRD^suzie's Avatar
try driving in wi.from mn to wi with no heat and degrees of only 5-10 degrees for 4 freakin hours..
tien285
Acura TL, RL & ZDX
Oct 22, 2012 04:13 PM
SpeedSin
11
Dec 6, 2008 06:32 AM
acuratl
Acura TL, RL & ZDX
Nov 5, 2007 04:13 PM
Nihilus
Jan 25, 2005 10:29 PM
servion
Sep 16, 2003 09:03 AM
