MSD ignition coils for 93 accord F22A engine!?
Hey everyone!
Im looking into upgrading my external coil on my 93 accord with an F22A engine recently swapped in. The reason is that i think my old external coil might be going bad...about 210,000 miles on it! So which of the coils from MSD would i be able to use they offer soo many....and then what else would i need to purchase to use this
? thanks for all the help guy!
Just because your coil has 210K on it doesn't mean it might be going bad....with the coil it usually either works or doesn't. IMO get out your volt-o-meter and check the specs in your chiltons/helms/haynes manual to see what resistance should be and if it is not in those specifications then replace it, don't just think a part is bad based off of miles.
If it is broken replace with either an upgraded ignition or retain oem
