whats the best stuff to use to stick carpet to my speaker box?
Old Jan 1, 2002 | 11:31 PM
Volcom's Avatar
Default whats the best stuff to use to stick carpet to my speaker box?
I bought some 3-m spray adhesive and was wondering if this was good enough? Also, does anyone have any good tips on getting the carpet on good and tight? Where should the seams be?
Thanks
Old Jan 2, 2002 | 09:08 AM
redblues's Avatar
New User
Default Re: whats the best stuff to use to stick carpet to my speaker box? (Alphanumeric)
I use 3m trim adhesive. If it makes it stick, it's good enough. The seams should be along seven edges of the box (three outer edges both sides and one cross edge). Some people put the edge on the middle of a plane with the outer edges doing the same to the outer planes of the box. It's up to you.
To get it on nice and tight you have to stretch the carpet while putting it on. Also helps to use a heat gun while you're at it. If you're paranoid you can screw the carpet down too along the corners.
Old Jan 2, 2002 | 09:51 AM
Volcom's Avatar
Default Re: whats the best stuff to use to stick carpet to my speaker box? (redblues)
thanks for the info
Righteous Fire
Audio / Security / Video
Oct 2, 2006 08:59 PM
hometheaterman
Feb 16, 2005 06:52 PM
debogsr
Apr 26, 2004 09:44 PM
crxforum
Mar 23, 2003 07:18 AM
balistic CRX
Feb 23, 2002 02:34 PM
