spoon vtec controller for a EG sir2 do they run good?
Old Dec 6, 2004 | 08:38 PM
Manny_Fresh's Avatar
Default spoon vtec controller for a EG sir2 do they run good?
does anybody have this set up in there car? I was thinking about buying this vtec controller but i was wondering if anybody knows if it runs good
Old Dec 6, 2004 | 08:50 PM
Blazin Civic's Avatar
Default Re: spoon vtec controller for a EG sir2 do they run good? (H2kEg6)
HUGE waste of money if your engine is stock
Old Dec 6, 2004 | 09:47 PM
endlesswinterco's Avatar
Default Re: spoon vtec controller for a EG sir2 do they run good? (Blazin Civic)
but i thought that a vtec controller added 50hp...haha
Old Dec 6, 2004 | 09:48 PM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2kEg6 &raquo;</TD></TR><TR><TD CLASS="quote">does anybody have this set up in there car? I was thinking about buying this vtec controller but i was wondering if anybody knows if it runs good</TD></TR></TABLE>
What are your goals with the car? I have no experience with the Spoon unit, but if it's anything like all of the other Spoon products...
I'll gladly recommend some other form of engine management if you tell us your goals.
Old Dec 6, 2004 | 11:24 PM
rodrez.'s Avatar
THe problem with the Spoon controller is that it doesn't allow you to adjust the fuel along with the change in crossover. It supposed to be used with a Spoon programed ECU, but a VAFC would be cheaper, and offer more tunability. Hondata would be a step beyond that.
Old Dec 6, 2004 | 11:46 PM
Soccerking3000's Avatar
Default Re: spoon vtec controller for a EG sir2 do they run good? (rodrez.)
first off it's "do they run well"
and the spoon vtec controller is just that a vtec controller it does nothing else. You shouldn't need to change the x-over point unless you have a dyno and a well modified engine. Otherwise it is a waste of money.
Old Dec 7, 2004 | 01:52 AM
eg6sir-s's Avatar
the spoon vtec controler does run good but it runs even better with a spoon built motor with spoon ecu. without any of that youre better off with a vafc2
Old Dec 7, 2004 | 04:14 AM
nub.96ek's Avatar
The Spoon controller on its own is pretty useless. Spoon only runs it as it is the only mod. not handled by the Spoon ECU. If ur ECU is stock it aint worth ****... even if it does fit nicely into your dash.
Old Dec 7, 2004 | 04:30 AM
Triscuit's Avatar
how much does it go for I bet he can purchase a V-AFC or V-AFC2 for around the same price.........
Old Dec 7, 2004 | 07:18 AM
Default Re: (Ronin EG6)
they go for around 80 bucks or so
Old Dec 7, 2004 | 04:00 PM
alright thanx guys i should just stick to the vafc thanx for the info
Eg6_rAcEr
42
Oct 5, 2006 03:34 AM
JDMTRSPORTS
Dec 5, 2005 08:25 AM
old_school_dohcvtec
Oct 9, 2005 12:05 PM
jaydm98
Aug 18, 2003 05:01 PM
AfEn808
Dec 7, 2001 12:13 PM
