need help with vss.
Old Dec 6, 2004 | 07:34 PM
jaydm ferio's Avatar
Default need help with vss.
hey guys i just did a swap about one month ago and my speedomator was working just fine, today when i went to work i noticed that it was not working. Im throwing code 17 so i know that its the vss. I looked at it and unpluged it, then pluged it back in. What would be the reason that it just stops working???
BTW i cant hit vtec anymore is this the reason?
Old Dec 6, 2004 | 07:35 PM
Ricey McRicerton's Avatar
Default Re: need help with vss. (jaydm ferio)
Yes, the connection could be going bad, could have rattled loose, or your VSS could be dying.
After you remove the connector and replug it, try to see if that fixes it. If not, I'd start looking for another VSS. Generally when they die, they go out intermittently.
Old Dec 6, 2004 | 07:36 PM
Default Re: need help with vss. (Ricey McRicerton)
will that cause my vtec not to hit?
nighttrain33's Avatar
If you tried to reset the system and it didn't fix the problem, why haven't you just tried replacing it and going from there? Sensor may just be bad.
-Shane
Old Dec 6, 2004 | 07:37 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydm ferio &raquo;</TD></TR><TR><TD CLASS="quote">will that cause my vtec not to hit?</TD></TR></TABLE>
Si senor.
GdmLaz's Avatar
yuh once you get an engine code ur vtec won't turn on and i had the same code just take the vss out and clean both connections
Old Dec 6, 2004 | 08:09 PM
Default Re: (Slammed92hbonN20)
thanx alot guys
Old Dec 6, 2004 | 08:54 PM
Br1anPham's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 &raquo;</TD></TR><TR><TD CLASS="quote">yuh once you get an engine code ur vtec won't turn on and i had the same code just take the vss out and clean both connections </TD></TR></TABLE>
Not always.
Lane
Nov 6, 2006 02:10 PM
jaydm ferio
11
Dec 13, 2004 07:19 PM
jaydm ferio
Dec 6, 2004 08:08 PM
dash8264
13
Feb 9, 2004 02:02 PM
SlippylesKB
20
Oct 18, 2003 04:32 PM
