More Tranny Symptoms...
Old Dec 6, 2004 | 05:57 PM
_Spugen_'s Avatar
Default More Tranny Symptoms...
First off the car is a 92 hatch.....I dont really drive the car alot considering it isnt registered or anything Ive maybe drove it 10 miles since i got it a couple months ago.....When i first got it it did not engage into first or reverse. I changed the fluid and installed poly bushings. Still didnt work then like a week or so later they magically somehow worked. Then about a month later i installed lowering springs and drove it around a mile or two at the most then just two days ago I go to move it and it dosent what so ever engage...I checked the linkages, fluids, and nothing.
What could possibly be a fix?
After talking to a buddy I kno he offered a 93 VX tranny (no grinds) with a almost new clutch for 250 installed...I still have to trailer the car about an hour away though....Is that a somewhat good deal?
Old Dec 6, 2004 | 06:31 PM
plusONE jboy's Avatar
seems like a good price with installation..
Old Dec 12, 2004 | 05:37 AM
Deemeetree's Avatar
Electrician
Turn your shifter around. Did it work?
Old Dec 12, 2004 | 02:17 PM
_Spugen_'s Avatar
^^ Nope it did not work....Ok anyone else car to chime in???
Once again the tranny will not engage into reverse...
Old Dec 12, 2004 | 04:25 PM
_Spugen_'s Avatar
Up.
Old Dec 12, 2004 | 04:32 PM
civictildeath's Avatar
Default Re: (SpugenEG)
just change the tranny. probsbly cheaper in the end and less of a headache
Old Dec 12, 2004 | 07:07 PM
mugenEG2's Avatar
Default Re: (civictildeath)
i dunno. perhaps your syncros or clutch not functioning? did you try putting it in another gear before going into 1st or reverse? try neutral-4th-reverse.
Old Dec 12, 2004 | 07:15 PM
=GAME='s Avatar
Default Re: More Tranny Symptoms... (SpugenEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpugenEG &raquo;</TD></TR><TR><TD CLASS="quote">
After talking to a buddy I kno he offered a 93 VX tranny (no grinds) with a almost new clutch for 250 installed...I </TD></TR></TABLE>
vx tranny is one you should stay away from. the gearing sucks. look around for a ex/si tranny for a little more. you wont be dissappointed.
Old Dec 12, 2004 | 07:29 PM
f1z1c's Avatar
Isnt reverse going to be the straight thru gear? So either the transmission is stuck ( missing a lot of teeth) or it is just a clutch thing. Have you had a clutch inspection? Did you look at the shift levers under the car?
Old Dec 15, 2004 | 03:40 PM
_Spugen_'s Avatar
Anyone else?
'00Accordster
Oct 12, 2008 08:53 AM
shadow_ridge
Dec 8, 2004 03:09 PM
crucial si
Jun 21, 2003 10:45 PM
JunIntegra
May 17, 2003 02:55 PM
