Hasport's ef b16 swap header.
Old Dec 6, 2004 | 04:59 PM
b16_madman's Avatar
Default Hasport's ef b16 swap header.
I showed people in the ef/crx forum, but didn't show it here. I haven't had any problems with it and it fit like a glove. Some welds could be better, but whatever. Just showing off an unnamed maker of the header.
That's all I have to contribute to this forum pictures wise. Only other thing done is foglight brackets but no pictures of them.
only scratched it once, and who knows how?!
Modified by B16_madman at 1:38 AM 2/11/2005
Modified by B16_madman at 1:39 AM 2/11/2005
Old Dec 6, 2004 | 05:12 PM
Nov!ce's Avatar
Is there a link to how it performs, hp/tq#s?
Old Dec 6, 2004 | 08:15 PM
b16_madman's Avatar
Default Re: (Nov!ce)
I'm hitting the dyno this saturday. Given my motor to still be in roughly the same condition (nearly another 6 months or so of more abuse) I hope to see some sort of gains, b/c my butt dyno sure does like the smoother midrange, or stronger mid.
Old Dec 7, 2004 | 10:05 AM
RCautoworks's Avatar
The end by the car looks like its pointing up, is that the case ? I have had problems with headers in b16 swaps in an ef not lining up, the header was always sitting higher.
Old Dec 8, 2004 | 04:59 PM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nov!ce &raquo;</TD></TR><TR><TD CLASS="quote">Is there a link to how it performs, hp/tq#s?</TD></TR></TABLE>
Old Dec 8, 2004 | 09:12 PM
b16_madman's Avatar
Default Re: (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16_madman &raquo;</TD></TR><TR><TD CLASS="quote">I'm hitting the dyno this saturday.</TD></TR></TABLE>
as far as hasport doing it, i have no clue. I wouldn't expect a ton.
Old Dec 10, 2004 | 08:29 AM
92hybridAccord's Avatar
From: In the heart of the ghetto of the, Suburbs NYC
Default Re: Hasport's ef b16 swap header. (B16_madman)
Do you happen to have more details on the make of this.
I'm going to attempt to make one for my h22 hatch, but i'm not sure how to go about as far as piping...bends etc etc
Can you provide more detail
Old Dec 10, 2004 | 09:46 AM
b16_madman's Avatar
Default Re: Hasport's ef b16 swap header. (92hybridAccord)
I didn't make it.
Old Dec 20, 2004 | 04:27 PM
b16_madman's Avatar
After header.
Results...
Before.
Not much difference, a lil less than a year of driving in between dyno's may be the case of not showing much diff. But I'm still happy.
Old Dec 23, 2004 | 12:11 PM
SEA Hag's Avatar
What header was used on the before test?
Old Dec 27, 2004 | 02:39 PM
b16_madman's Avatar
Default Re: Hasport's ef b16 swap header. (SEA Hag)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SEA Hag &raquo;</TD></TR><TR><TD CLASS="quote">What header was used on the before test?</TD></TR></TABLE>
stock manifold
Old Dec 27, 2004 | 05:37 PM
keithg's Avatar
Was it the stock JDM B-16 manifold with the two O2 sensors and dual downpipes?
Old Dec 28, 2004 | 06:13 AM
b16_madman's Avatar
Default Re: Hasport's ef b16 swap header. (keithg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keithg &raquo;</TD></TR><TR><TD CLASS="quote">Was it the stock JDM B-16 manifold with the two O2 sensors and dual downpipes?</TD></TR></TABLE>
yes, pre obd goodness. my butt dyno said it felt more power in mid range, and felt smoother, but the two dyno graphs are hard to see much difference.
They were done on the same dyno, just about 10 months apart of DD abuse.
weight reduction and bling is about all i got out of that header i think Might need a lil more r&d? It did fit well though.
Old Dec 28, 2004 | 06:47 AM
Any way you can take a better pic of where the o2 sensors are located.
Old Dec 31, 2004 | 12:59 PM
keithg's Avatar
Default Re: Hasport's ef b16 swap header. (90blackcrx)
this picture is from a different angle than the picture above.
http://www.hasport.com/Products/Headers.htm
Old Jan 1, 2005 | 11:45 AM
shocker's Avatar
hmm doesn't look to bad,dyno results could vary with different b16's...anyone else run this header i would like to see
Old Jan 11, 2005 | 08:38 AM
C_REX's Avatar
Default Re: (shocker)
Anybody know where else to buy this Hasport header for less than $400?
Old Jan 11, 2005 | 01:08 PM
b16_madman's Avatar
Default Re: (C_REX)
ebay, just gotta keep your eyes open
Old Jan 12, 2005 | 09:30 AM
C_REX's Avatar
Default Re: (B16_madman)
Wanna sell your's?
Old Jan 12, 2005 | 11:32 AM
b16_madman's Avatar
Default Re: (C_REX)
...and replace it with what?
Old Feb 10, 2005 | 09:38 PM
b16_madman's Avatar
nuther pic in bay
just to complete the thread
Old Feb 10, 2005 | 09:40 PM
b16_madman's Avatar
Default Re: (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">The end by the car looks like its pointing up, is that the case ? I have had problems with headers in b16 swaps in an ef not lining up, the header was always sitting higher. </TD></TR></TABLE>
yeh, it does, they had to touch up the ex. for it to meet up, which will prolly give me hassles when i redo the exhaust w/rsr
Old Feb 12, 2005 | 08:04 AM
keithg's Avatar
The Hasport header is designed to mount up to the stock 88-91 Civic/CRX cat and exhaust on the DX/LX/EX and Si with no mods or rotating the cat, and has the dual oxygen sensors for the car to run properly.
Old Feb 12, 2005 | 08:12 AM
b16_madman's Avatar
Default Re: (keithg)
FYI...I had to rotate my cat., but it could be when they redid the piping after the swap was done.
Also the header does stick up towards the bottom of the car some...
Old Mar 9, 2005 | 07:03 AM
Autoworks's Avatar
So with this header, did you just have to plug in the O2 sensors, and thats it? No extra ecu wiring or anything? That is my biggest concern right now with searching for a header.
