O2 sensor help
I have a code 41 primary O2 heater. Is that the O2 sensor that is closest to the head in a 95 civic ex? Also what the best way to get the o2 sensor off the manifold because that thing is on there tight.
thanks
thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">is it the same code? Did you reset the ecu after changing the sensor?</TD></TR></TABLE>
will pulling the power to the battery reset the ecu? I am used to working on OBD0 stuff.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpine »</TD></TR><TR><TD CLASS="quote">what size wrench ?</TD></TR></TABLE>
7/8ths wrench to remove the O2 sensor...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed92hbonN20 »</TD></TR><TR><TD CLASS="quote">ayy yay lol u could take that **** out with anything even an adjustable the problem is if i replaced the sensor and im still gettin the same code wat else can i do</TD></TR></TABLE>
that is your problem....your primary 02 sensor so if you replace the sensor then I will correct the problem. It isn't like you were gettin a CEL and just guessing the CEL tells you want is wrong, A 7/8ths cresant wrench will get the O2 sensor off and you can just replace it and put the new one back in and your problem will be fixed.
