Do i need to upgrade my stock Rods?
Old Dec 6, 2004 | 04:34 PM
HamiltonRex's Avatar
Default Do i need to upgrade my stock Rods?
Im planning a 'mild' NA build for January/Febuary..
I plan to drop some P30 pistons with OEM rings and bearings in my GSR Bottom end, along with a new ITR water/oil pump. And seals and gaskets and ARP rod bolts and head studs. Stock OEM 3 layer gasket.
Then for the cylinder head.. Its going to be probably stock CTR with fierra valvetrain and cams i havent decided, something that peaks around 8.5k and works well with 11.6:1 CR (ANY sugestions???), and stock valves.
The boltons will be BISI header, 2.5" exhaust. Abes reworked IM, 65/70mm TB, RC 310cc Injectors, AEM FPR, and a walbro pump.
It will be tuned on the street with a wideband and Ubderdata.
Now i want to keep this a 'budget' build for my dailydriver. The bisiheader.. thats if funds permit what i have now i will reuse.
Should i upgrade to eagle rods, they run about $400. Is it nesecary or should i spend the $400 elsewhere. The motor will only see 8.5k redline. Will my GSR rods be okay?
I want to aim around 190-200WHP with lots of tuning Is there anything i should change or alter to help aim this on a 'budget'?
Thanks
Old Dec 6, 2004 | 04:57 PM
civicgsr19's Avatar
Default Re: Do i need to upgrade my stock Rods? (HamiltonRex)
Gsr rods will be fine, you aren't really going over the stock redline, the arp rod bolts should be enough security.
Old Dec 6, 2004 | 05:35 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: Do i need to upgrade my stock Rods? (civicgsr19)
even at high output allmotor setups, stock rods are alright. how often do you see a 12.5:1 ctr piston LS/VTEC throw a rod(assuming it's built properly)?
stock rods are fine, and if it'll make you sleep better at night, buy some ARP rod bolts.
btw, this is mike k. not emerica.
Old Dec 6, 2004 | 06:52 PM
slrh22hatch's Avatar
Default Re: Do i need to upgrade my stock Rods? (Emerika)
I wouldnt say u need them but it would be a good security blanket. You can buy a set of Eagle Rods from Camp1320 for like $299 shipped
Old Dec 6, 2004 | 09:48 PM
irev210's Avatar
Default Re: Do i need to upgrade my stock Rods? (slrh22hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slrh22hatch &raquo;</TD></TR><TR><TD CLASS="quote">I wouldnt say u need them but it would be a good security blanket. You can buy a set of Eagle Rods from Camp1320 for like $299 shipped </TD></TR></TABLE>
of course, when it isnt your money it is easy to spend it
No, you dont need to spend 300+ on rods for 200-250hp all motor build
Old Dec 7, 2004 | 12:25 AM
UncleD's Avatar
Default Re: Do i need to upgrade my stock Rods? (irev210)
If you're only gonna be revvin to around 8,500, then I wouldn't say that it's necessary. The only reason I would be conserned with your build up is if you were revvin way high and stretched a rod. Other than that, like these other fellas said, do some rod bolts and 8.5 is no problem all day every day!
Old Dec 7, 2004 | 04:57 PM
Default Re: Do i need to upgrade my stock Rods? (clean rice)
Thanks. That way I can run GSR bearings without worrying about clearance (I will still check)
Seems like all thats needed for the bottom end p30 pistons. And new bearings, seals, gaskets, waterpump oilpump and timing belt
Then just build the head and with tuning i might hit 190-200 whp
Old Dec 7, 2004 | 05:02 PM
Team 4's Avatar
It sounds like we have very similar buildups and goals.
I used the GSR Rods with the ARP rod bolts. So far, everything's been fine!
(20,000 km's and lots of trips to the strip/autocross)
Old Dec 7, 2004 | 05:31 PM
ShaunRR's Avatar
HT White Ops
Community Builder
I have friend who liked to rev their stock GSR bottom ends to 9500 on a regular basis, so you will be fine.
slowsleeper
48
Feb 8, 2015 09:19 PM
UserX826
Mar 9, 2009 04:38 AM
Ice-Nine
Feb 27, 2008 08:39 AM
tealsvteceg
Feb 14, 2008 08:27 PM
all-mtr-teg
Mar 17, 2007 05:49 AM
