itr head on b20 block.
Old Dec 6, 2004 | 03:55 PM
jdm92teg's Avatar
Default itr head on b20 block.
a friend of mine jus told me he would sell me a itr head for 675, my question is, is this a good price? come wit full titanium valvetrain, aebs manifold valve cover etc. also if i bought it and put it on my stock b20 bottom end what kind of numbers should i expect. what kind of oil/water pump should i run with this? and i use the b20 head gasket right?? thanx for the info
Old Dec 6, 2004 | 05:34 PM
Nov!ce's Avatar
I don't know about the pricing, but check this link out. http://www.c-speedracing.com/h...c.php
Old Dec 6, 2004 | 06:19 PM
rodimus's Avatar
Default Re: (Nov!ce)
not sure about the head gasket, but i know that's a good price if he's including a decent valvetrain AND the AEBS IM. i'd get it regardless.
i believe you will have to run the itr/gsr water pump.
Old Dec 6, 2004 | 06:55 PM
slrh22hatch's Avatar
Default Re: (EVOL)
You can run a B20 water pump and oil pump its all the same ****. Dont let anyone tell u they are any different. Yes you run the B20 head gasket
Old Dec 6, 2004 | 09:46 PM
irev210's Avatar
Default Re: (slrh22hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slrh22hatch &raquo;</TD></TR><TR><TD CLASS="quote">You can run a B20 water pump and oil pump its all the same ****. Dont let anyone tell u they are any different. Yes you run the B20 head gasket</TD></TR></TABLE>
the water pump is different than a vtec water pump
both will work, most people prefer the vtec water pump/timing belt
and yes, 675 is a killer deal if it is complete
Old Dec 7, 2004 | 10:55 AM
aeon's Avatar
the gsr/itr water pump is different, there's 22 teeths on the gsr/itr water pump and 19 on the non-vtec. If you have a vtec head then I would suggest you go with the vtec one. also get a gsr/itr oil pump.
Old Dec 7, 2004 | 11:22 AM
irev210's Avatar
Default Re: (aeon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeon &raquo;</TD></TR><TR><TD CLASS="quote">the gsr/itr water pump is different, there's 22 teeths on the gsr/itr water pump and 19 on the non-vtec. If you have a vtec head then I would suggest you go with the vtec one. also get a gsr/itr oil pump.</TD></TR></TABLE>
18 tooth
oil pumps are the same
and switching to vtec pump is just an option.
Old Dec 7, 2004 | 11:51 AM
hybridpatient95's Avatar
Default Re: (irev210)
yea its a option but i would rather be safe unless you want your engine to have a slow painful death
Old Dec 7, 2004 | 12:02 PM
irev210's Avatar
Default Re: (kinkbmx159)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kinkbmx159 &raquo;</TD></TR><TR><TD CLASS="quote">yea its a option but i would rather be safe unless you want your engine to have a slow painful death </TD></TR></TABLE>
thats talking from what experience?
Old Dec 7, 2004 | 12:46 PM
chad174's Avatar
That's an awesome deal even for just an ITR head with a valvetrain. go for it. And by the way...all 1996+ b-series oil pumps are the same, but the water pumps are different. Use the b20 head gasket.
Old Dec 7, 2004 | 09:01 PM
Hella_Fresh's Avatar
Default Re: itr head on b20 block. (jdm92teg)
awsome deal if its complete.. b20 head gasket and i would choose a gsr oil pump. drop some ctr pistons in that, with some good cams... that will be one fun ride!
Old Dec 7, 2004 | 09:03 PM
RenoRacing's Avatar
Default Re: itr head on b20 block. (sXekid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sXekid &raquo;</TD></TR><TR><TD CLASS="quote">awsome deal if its complete.. b20 head gasket and i would choose a gsr oil pump. drop some ctr pistons in that, with some good cams... that will be one fun ride! </TD></TR></TABLE>
with 3mm of blowby!
Old Dec 7, 2004 | 09:08 PM
or better yet, hook up the head... put 13:1 pistons in and you get 2.1 liters with out stroking or sleeving the block, but then agian if your going to drive it all the time.. thats not a good idea
Old Dec 7, 2004 | 09:12 PM
RenoRacing's Avatar
how do you gain displacement by raising the compression?
Old Dec 7, 2004 | 09:16 PM
Default Re: itr head on b20 block. (RenoRacing)
dont ask me! haha i seen it in Sport Compact Car and this guy had a eg with a b20 block and bored it over .20 over and it said he placed 13:1 compression pistons in and it bumped it to 2.1 with out stroking or sleeveing the block.. so idk i was just going off what it said.
Old Dec 7, 2004 | 09:23 PM
RenoRacing's Avatar
boring adds displacement. not quite that much but a little none the less.
everything you read isn't always correct! just a little advice for ya.
Old Dec 7, 2004 | 09:27 PM
hmm... good point... damn magazine.. im never buying that **** again!! haha JK, and im sorry if we jacked this guys thread for the guy with the thread... all i have to say is TAKE IT!! its a good deal!
Old Dec 7, 2004 | 10:37 PM
jdm92teg's Avatar
thanx for all the help
Old Dec 7, 2004 | 11:28 PM
rodimus's Avatar
i don't think you got what he meant by 3mm of blowby.
ctr pistons=81mm
b20 block=84mm
you can't put ctr PISTONS in a b20 block man.
well you can, but it will NOT WORK.
SIEf89
Dec 31, 2011 03:02 PM
Steven.
Aug 19, 2008 04:45 PM
EG6R
11
May 11, 2005 08:05 AM
mrxracing
Jun 6, 2004 08:23 PM
AudioXtremes
Mar 31, 2003 02:47 PM
