Are OBD2 H22 Heads Compatible with an OBD1 H22 Bottom End?
Old Dec 6, 2004 | 03:46 PM
dacosta's Avatar
Default Are OBD2 H22 Heads Compatible with an OBD1 H22 Bottom End?
Does any one know if OBD2 H22 Heads are compatible with an OBD1 H22 Bottom End?
If so, is it a direct replacement? Any additional wiring needed to work?
Thanks In Advance,
Darwin
Old Dec 6, 2004 | 04:16 PM
md23vtec's Avatar
Default Re: Are OBD2 H22 Heads Compatible with an OBD1 H22 Bottom End? (dacosta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dacosta &raquo;</TD></TR><TR><TD CLASS="quote">Does any one know if OBD2 H22 Heads are compatible with an OBD1 H22 Bottom End?
Thanks In Advance,
Darwin</TD></TR></TABLE>
yes!
Old Dec 6, 2004 | 07:06 PM
dacosta's Avatar
Default Re: Are OBD2 H22 Heads Compatible with an OBD1 H22 Bottom End? (md23vtec)
Thanks...I was pretty sure that it was compatible. However, I'm not sure if one needs to do any additional wiring?
Old Dec 7, 2004 | 06:17 AM
jackstands's Avatar
What about the crank angle sensor?
Old Dec 7, 2004 | 08:42 AM
dacosta's Avatar
Default Re: Are OBD2 H22 Heads Compatible with an OBD1 H22 Bottom End? (jackstands)
Also aren't there differences with the distributor of OBD1 & OBD2 Engines?
Old Dec 7, 2004 | 10:38 AM
PrettyLude's Avatar
crank angle sensor is in the distributor
Old Dec 7, 2004 | 11:35 AM
dacosta's Avatar
Default Re: (PrettyLude)
So if I were to put an OBD2 Head onto a OBD1 Block, how should go about it?
Would I be able to use an OBD1 distributor if the car is OBD1 or would I need to use the OBD2 distributor?
Thanks in advance.
Old Dec 7, 2004 | 12:47 PM
PrettyLude's Avatar
you would have to use an obd1 distributor, becuase the obd2 block has the crank positive sensor on the oil pump, as the obd1 has it in the distributor
Old Dec 7, 2004 | 12:49 PM
dacosta's Avatar
So other than that, I assume everything would just bolt on up, right??
Thanks for everyone's help.
Regards,
Darwin
Modified by dacosta at 5:43 PM 12/8/2004
Old Dec 8, 2004 | 08:44 AM
dacosta's Avatar
Default Re: (dacosta)
Would there be anything else that I would need other than the OBD1 Distributor?
Thanks Again,
Darwin
Old Dec 9, 2004 | 02:31 PM
dacosta's Avatar
By the way, ya happen to know if there's a major difference between a US & a JDM H22 Head?
Old Dec 9, 2004 | 05:42 PM
satan_srv's Avatar
no difference within the same gen motor
Old Dec 9, 2004 | 09:05 PM
dacosta's Avatar
Default Re: (satan_srv)
Thanks
Old Dec 9, 2004 | 09:38 PM
johann's Avatar
i asked this question 2 years ago . no one ever answered. obd1 distributer will work on obd2, but it will not work the other way around
sirtef9
Jul 11, 2008 12:19 PM
granturismonut2
Mar 31, 2008 09:54 AM
ziptie
Jul 23, 2007 12:01 PM
HotRodEG6
Feb 9, 2004 10:39 AM
