new h22 dyno
Old Dec 6, 2004 | 12:59 PM
JDogg's Avatar
Default new h22 dyno, jun3 cams 217hp
this motor is basicly the same as the one that we did the cam test on, with the exception of new valves cause all the exh valves were bent when we dyno'd the other cams, and it has jun stage 3 cams, it still has stock block and other than new valves a stock head
the red line was base line done on a previous tune, green was after cam gear tuning (only on the intake side) and swapping from a dookie 2.5 inch accord aem cai and 58mm throttle body to a semi getto 3inch intake and 68mm throttle body
Modified by JDogg at 10:55 PM 12/6/2004
Old Dec 6, 2004 | 01:32 PM
Peter K's Avatar
New User
Default Re: new h22 dyno (JDogg)
What header were are you using currently? those are some damn good numbers on stock compression
Old Dec 6, 2004 | 01:35 PM
JDogg's Avatar
Default Re: new h22 dyno (Peter K)
here's the setup for lazy people
getto 3inch intake
68mm tb
euro r intake manifold
stock head with ferrea valves
rocket springs/retainers
jun3 cams
one hayame cam gear on the intake side, stock gear on the exh
and to top it all off a ebay weapon r header with the collector loped off and 2.5 inch pipe welded on
all tuned by me with an aem ems
this is the same motor we tested the rocket regrinds on, just that all the exh valves were bent when we did that test... here is the link to that thread. https://honda-tech.com/zerothread?id=1017085
Old Dec 6, 2004 | 02:19 PM
Silverpike's Avatar
Just so I understand this Jason:
Jun 3 > Rocket grinds ???
I know there are some other variables here, but I am interested in a cam comparison. Did you notice any ignition timing differences worth mentioning?
Old Dec 6, 2004 | 02:27 PM
JDogg's Avatar
Default Re: new h22 dyno (Silverpike)
cant compair this to the rocket stuff... the motor had 8 bent exhaust valves when we did the rocket test.... they have since been fixed.
i think kteller is selling the regrinds with valve springs/retainers for 535.. you cant beat that... hell we paid quite a bit more than that for just the jun3's
soloDC
150
Aug 20, 2012 09:15 PM
BABY NSX
43
Jun 14, 2007 10:14 AM
JDogg
Dec 8, 2004 02:18 PM
. o 69 o .
41
Jul 15, 2004 09:27 PM
kwik93si
Jul 8, 2003 11:37 AM
