si wire harness on hf will it work????//////
Old Dec 6, 2004 | 12:55 PM
lemongreenhatch's Avatar
Default si wire harness on hf will it work????//////
ok i have 89 hf but i have an 91 si engine harness ok the ? i have is there anyway i can wire the si to work cuz on the driver side shock tower has a clip that doesnt clip up
Old Dec 6, 2004 | 12:58 PM
Magick211's Avatar
Default Re: si wire harness on hf will it work????////// (poorman-type-r)
As far as i know you can use the si harness i know the hf harness has like one or two extra clips. but the si harness should work
Old Dec 6, 2004 | 01:03 PM
dr_latino999's Avatar
Why you want to switch it over? The HF harness is identical (minus year variations) to the same year SI harness except it has a few more plugs.
Old Dec 6, 2004 | 08:12 PM
Default Re: si wire harness on hf will it work????////// (dr_latino999)
im not tryin to switch over i still have the stock hf motor in the car i just got the car with out the wire harness and yes they are i dentical but the main plug next 2 the green clip for the register box does not clip...i tryed to take out the pins and plug them straight but the si harness has 2 less wires...i would use hf harness but no 1 semms to have 1 for sale
Old Dec 6, 2004 | 11:01 PM
Burlyirishdude's Avatar
the resistor Clip doesn't fit? hmm that's weird...89 - 90's had some minor changes....well if all else fails bro..you can go and rip the resistor plug off of some other Hf harness and butt splice it to the SI harness...count the pins.....and get back to us....i'd like to know if there is a differnece in the injectors and the amount of flow being dispensed.....
Old Dec 7, 2004 | 09:52 AM
Default Re: si wire harness on hf will it work????////// (Burlyirishdude)
no the register box clip fits its the 1 next to it the main clip ill get pics
Old Dec 7, 2004 | 10:43 AM
Sharpview's Avatar
The 88 Si harness has a square plug and the 89-91 Si harness has a round plug at the injector resistor. Are you sure you have a 91 harness and an 89 hf?
Old Dec 7, 2004 | 11:03 AM
Default Re: si wire harness on hf will it work????////// (Sharpview)
maybe i have a 88 si harness
Old Dec 12, 2004 | 09:29 PM
gutted's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sharpview &raquo;</TD></TR><TR><TD CLASS="quote">The 88 Si harness has a square plug and the 89-91 Si harness has a round plug at the injector resistor. Are you sure you have a 91 harness and an 89 hf?</TD></TR></TABLE>
are you saying the resistor box plug is round on the 88? or the 2nd plug by the resistor box is round?
Old Dec 12, 2004 | 09:34 PM
Default Re: si wire harness on hf will it work????////// (gutted)
the second i just got a hf wire harness
Old Dec 12, 2004 | 10:11 PM
gutted's Avatar
you got PM about ur harness
K20AllMotorEF8
Feb 11, 2012 11:38 AM
crx89backedout
Jan 14, 2010 03:36 AM
Boost Junkie 83
16
Apr 2, 2007 06:28 PM
markgo
Feb 29, 2004 06:13 PM
ITSTOCK
Nov 15, 2003 03:51 PM
