90 teg installing a jdm cluster
Old Dec 6, 2004 | 11:06 AM
04falcon's Avatar
Default 90 teg installing a jdm cluster
I just purchased a 90 teg jdm cluster and plan to install it into my 90 usdm teg.Is there anything I have to do for wiring so it will work? Or do I just need to plug it in?
Old Dec 6, 2004 | 11:14 AM
Colin's Avatar
Default Re: 90 teg installing a jdm cluster (04falcon)
just plug it in.... depending on what options your car has the new cluster may not have the appropriate lights (i.e. abs, cruise....). So if you want to you can also pull the tach out of the jdm clutser and put it into your usdm cluster. That is if you bought the cluster for the higher rpm tach, which I imagine you did.
na88lx4d
Mar 2, 2011 06:12 PM
iheartmyej8
Feb 21, 2006 07:02 PM
crexer
Jul 6, 2004 08:20 AM
junya16
Mar 5, 2003 01:16 PM
Butch
Sep 24, 2002 06:00 PM
