turbo b16 hatch
i have a 91 hatch with a jdm b16a turbocharged i have been having overheating problems so i both exuast wrap/ fluidyne radiator and a brand new termostat and my temp still goes up after about a 25 minutes of driving please help
yea mine does the same thing. long drives, it gets WAY hot. sucks.
what im going to try is running two slim fans covering the whole radiator instead of just the stock on i have now, and run a toggle switch inside the car which will turn on the second fan to try to help matters.
i also have a smei clogged cat, and still sotck exhaust, so once ive fixed that the headers wont get as hot, and the temps might be better from that as well. also important to note i dont have a turbo, but my suggestion may help you.
double check (although im sure you did) that your relay clicks and the fan comes on once its warm/hot.
good luck, and if you find a flaw in your cooling system thats a repalacable part, post the info here
tokes
Mar 4, 2005 08:16 AM
EGhatched
14
Mar 27, 2004 05:15 AM
miataguy
19
Aug 3, 2003 05:20 PM
