Painting S2K rims...
Old Jan 1, 2002 | 07:07 PM
Blue-Civic-Hybrid's Avatar
Loved
Default Painting S2K rims...
I recently got an extra set of S2k rims for AX and i want to paint them a nice gunmetal grey. I have painted before, but i just used flat black paint on some stock rims. As for the questions, I just want to know what needs to be done in the preparation of the rims, with the tires mounted. Will I need to sand the rims by hand to help the paint adhere better? and if i do, what grit sandpaper should i use? I don't want to screw these rims up because they are in really good condition, and they are a second set, and if they look good, i just might want to paint my original ones. the paint I am using is called Dupli-color wheel coating bought from Kragen..and the reason i posted in this section is beacuse i noticed a lot of painted rims here, some by hand, others not. any help or info would be appreciated...
Old Jan 1, 2002 | 11:39 PM
NOPD's Avatar
Default Re: Painting S2K rims... (Blue-Civic-Hybrid)
I used a 300 grit wet sand paper and sanded off all the clear coat. Then I used lacquer thinner to wipe it clean. I then just used some cheap walmart paint and painted about 4 layers of coat. take about 30 minutes between each coat. I than used about 3 clear coat. It sticks like white on rice and barely scratch or anything. so hope that helps
Old Jan 1, 2002 | 11:42 PM
Beyond Imagination's Avatar
I suggest getting them powdercoated ...
Old Jan 2, 2002 | 10:10 AM
Loved
Default Re: Painting S2K rims... (NOPD)
Thanks for the response about the 300 grit wet sandpaper..i think i will check into that and start sanding today..if i find some...and as for the powdercoating..it is a little expensive compared to painting it yourself..200 plus for powdercoating compared to 20 bucks for painting it yourself....
Old Jan 2, 2002 | 10:25 AM
Phase1 EG's Avatar
I to would recomend powder coating..Ive seen some home paint jobs gone horribly wrong...specially on s2k wheels..they aren't cheap
Old Jan 2, 2002 | 04:27 PM
Loved
Default Re: Painting S2K rims... (Phase1 EG)
Too late, i already painted them..and they look pretty good in my opinion..i will post pics once i figure out how too...and i just did an experiment on one of the front rims..i didn't sand it, just cleaned it well with a cleaner..and painted over the clearcoat...time will tell how long it will last...
Old Jan 2, 2002 | 04:30 PM
EG8R's Avatar
Default Re: Painting S2K rims... (Beyond Imagination)
Old Jan 3, 2002 | 07:03 AM
Loved
Default Re: Painting S2K rims... (mr. skelly)
Powdercoating cost money...but i will probably get them powder coated later on..but for now this an experiment in painting...and so far it looks successful...
Old Jan 3, 2002 | 07:07 AM
eg6ajk's Avatar
when done well, paint will hold on more then well...I have done over 5 sets, since some are over 2-3 years old now....they still look very good.....you can even bake them in hot oven to cure the paint...
LaCuRa
Feb 1, 2009 09:46 PM
lj420p
May 21, 2004 11:21 AM
typeass
May 19, 2004 06:19 AM
thisbwill
Jun 19, 2003 05:31 PM
Superdragr45
Oct 5, 2002 07:23 PM
