15X7 with a 40mm offset on a 96 ek Will it rub?
Old Dec 6, 2004 | 08:35 AM
whitemike1644's Avatar
Default 15X7 with a 40mm offset on a 96 ek Will it rub?
and if so what tire size would you reccomend for daily use? and if i did want to run a wider tire like 225 series drag radial in the front would i just have to raise the car or set my springs HELLA stiff?
Old Dec 6, 2004 | 08:41 AM
phoshEEzy mahnEEzy's Avatar
Default Re: 15X7 with a 40mm offset on a 96 ek Will it rub? (whitemike1644)
<FONT COLOR="orange">I have 15x7 +35 with 205/45's no rubbing issues. </FONT>
Old Dec 6, 2004 | 08:43 AM
Default Re: 15X7 with a 40mm offset on a 96 ek Will it rub? (phoshEEzy mahnEEzy)
how low are you though and what the difference with the offsets anyways?
Old Dec 6, 2004 | 09:00 AM
-Gambit-'s Avatar
i am running a 205/45/16 with a +42 offset and no rub and i am tucking the tires
Old Dec 6, 2004 | 09:02 AM
esoterEK..'s Avatar
NOPE
Old Dec 6, 2004 | 09:09 AM
Default Re: 15X7 with a 40mm offset on a 96 ek Will it rub? (esoterEK..)
even if i run a 225/50 series tire? because i was thinking about getting some drag radials in the front the BFG's are those any good or would you guy suggest a better tire or tire size? and what should i run for the rears?
Old Dec 6, 2004 | 09:18 AM
Unsivil_audio's Avatar
+40 will suck the tire into the wheel well more than +35. The closer you get to zero the closer you get to the center of the wheel. So at +0 offset the hub is bolting to the center of the wheel.
HamiltonRex
Oct 9, 2006 04:03 AM
SJR
Dec 3, 2004 08:25 AM
Mr. Vapor
Jul 1, 2002 11:23 AM
ginnis
May 11, 2002 06:34 PM
