axle wtf?????
Old Dec 6, 2004 | 03:16 AM
JDM96SpecCTR's Avatar
Default axle wtf?????
i just did my clutch yesterday, but i cant get the pass side axle back in for the life of me. me n 2 friends tried at it for over an hour and eventualy gave up. now ive done like 5 motor swaps before, so i know what im doing as do the other 2 guys, but we were stumped. the axle was put back in the tranny first and i cant get it to push through the hub. should i take it out of the tranny and try the huib first? thats about the only thing i didnt try yet. never had a problem putting an axle back in before
Old Dec 6, 2004 | 03:28 AM
beerbongskickass's Avatar
Default Re: axle wtf????? (JDM96SpecCTR)
I had that problem the last time I replaced my axle, I was stumped as well. I tried a little grease and eventually got it in far enough so I could get the axle nut on it and get it in the rest of the way. It was a brand new axle so I am guessing that is why it didn't feel like going in, but I'm really not sure. They have always went in fairly easy for me.
Old Dec 6, 2004 | 03:48 AM
chris_c's Avatar
Default Re: axle wtf????? (beerbongskickass)
clean the splined surface of the hub and axle, re-lube and it will slide right in. you don't try to slide up in your woman dry do you?
Old Dec 6, 2004 | 04:16 AM
ironcheftony's Avatar
make sure the snapring or watever is called is not damaged, dented and such, if so, get a new 1
Old Dec 6, 2004 | 04:17 AM
Default Re: axle wtf????? (chris c)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris c &raquo;</TD></TR><TR><TD CLASS="quote">clean the splined surface of the hub and axle, re-lube and it will slide right in. you don't try to slide up in your woman dry do you?</TD></TR></TABLE>
So I need to lick the hub's nipple and play with it's **** before I stick the axle in?
Old Dec 6, 2004 | 04:35 AM
chris_c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by beerbongskickass &raquo;</TD></TR><TR><TD CLASS="quote">
So I need to lick the hub's nipple and play with it's **** before I stick the axle in?</TD></TR></TABLE>
nah... i'm to old for that foreplay ****.... i just lube the woman up too... lol...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony &raquo;</TD></TR><TR><TD CLASS="quote">make sure the snapring or watever is called is not damaged, dented and such, if so, get a new 1</TD></TR></TABLE>
he said the axle is in the tranny fine. the hub just won't slide over the axle. there is probably just a build up of corrosion and grime on the splines. cleaning the splines with a penetrating fluid like PB Blaster and then apply a light coat of grease should def. take care of that...
Old Dec 6, 2004 | 04:42 AM
lol ur never too old for some foreplay..
anyway thanks for the suggestions, i also figured i might need some grease but i didnt have any, i soaked it in WD tho but it didnt help ****. so ill try the grease today
Old Dec 6, 2004 | 05:35 AM
chris_c's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM96SpecCTR &raquo;</TD></TR><TR><TD CLASS="quote">
anyway thanks for the suggestions, i also figured i might need some grease but i didnt have any, i soaked it in WD tho but it didnt help ****. so ill try the grease today</TD></TR></TABLE>
how did it pull apart? easily? do you have a little brass wire brush? spray on your penetrating fluid and use the little brass wire brush to clean out the splines.
you didn't drop the axle and bur the end of it did you?
Old Dec 6, 2004 | 10:06 AM
you didn't drop the axle and bur the end of it did you?</TD></TR></TABLE>
well my friend took the axle out, and i didnt notice any damage on it, so i dont think thats it, i hope anyway
Old Dec 6, 2004 | 10:19 AM
vtec69's Avatar
sometimes rust gets inside of the hub and causes the axle to get stuck or causes the axle to go in very diffficult.
Rub some anti-seeze on the spline and make sure the spline are lined up with the axle and the hub and hopefully that will work
good luck
Old Dec 6, 2004 | 12:11 PM
Default Re: axle wtf????? (vtec69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec69 &raquo;</TD></TR><TR><TD CLASS="quote">sometimes rust gets inside of the hub and causes the axle to get stuck or causes the axle to go in very diffficult.
good luck</TD></TR></TABLE>
You need to give your woman more sex if she is getting rust inside her... what were we talking about again? lol...
Old Dec 6, 2004 | 12:46 PM
You need to give your woman more sex if she is getting rust inside her... what were we talking about again? lol... </TD></TR></TABLE>
lol good one
Old Dec 6, 2004 | 01:07 PM
nfinitecc's Avatar
i had this same damn prob 2 days ago...it wasn't dirty damaged or bent just wouldn't go...i got a 6" triangle file and filed some on every tooth of the axle and spindle....still wouldn't....so i put a piece of wood on the hub and hit the **** out of it with a hammer untill i could get the nut on and pull it through...it made me crazy
Old Dec 6, 2004 | 01:34 PM
Default Re: axle wtf????? (nfinitecc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nfinitecc &raquo;</TD></TR><TR><TD CLASS="quote">i had this same damn prob 2 days ago...it wasn't dirty damaged or bent just wouldn't go...i got a 6" triangle file and filed some on every tooth of the axle and spindle....still wouldn't....so i put a piece of wood on the hub and hit the **** out of it with a hammer untill i could get the nut on and pull it through...it made me crazy</TD></TR></TABLE>
yea i tried wood on the hub and i tried without wood on the hub...didnt do ****...
PhantomPharter
20
Apr 4, 2012 03:14 PM
stockb18c
Transmission & Drivetrain
Apr 5, 2009 07:50 PM
aziaticvang
Dec 27, 2007 05:22 PM
civicjdmb16a
Dec 29, 2005 09:10 PM
GSpeedR
Aug 11, 2002 03:06 PM
