Steering and Idle
When I first move the wheel out of a centered position the car seems to idle pretty rough for an instant- almost like it wants to die, it wasn't so bad before, but it seems to be getting progressively worse. Just got a new battery, what else could it be?
IAC is the more likely culprit but preludes also have a power steering pressure switch. When PS pressure goes up, it tells the ECU to increase idle to compensate for extra load. Clean IAC and clean up the switch too, it's on your pressure metal line. It will be a messy job and you'll lose almost all of your p.s. fluid, but just think of it as a p.s. flush.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delguiner »</TD></TR><TR><TD CLASS="quote">IAC valve maybe! try cleaning it!</TD></TR></TABLE>
If not, check alternator output.
Fuzzychaos
Honda Civic (2001 - 2005)
Jun 21, 2015 11:50 AM
ftrms
Mar 31, 2010 07:18 PM
