Steering and Idle
Old Dec 5, 2004 | 10:59 PM
dj626's Avatar
Default Steering and Idle
When I first move the wheel out of a centered position the car seems to idle pretty rough for an instant- almost like it wants to die, it wasn't so bad before, but it seems to be getting progressively worse. Just got a new battery, what else could it be?
Old Dec 6, 2004 | 04:21 AM
delguiner's Avatar
Default Re: Steering and Idle (dj626)
IAC valve maybe! try cleaning it!
Old Dec 6, 2004 | 07:46 AM
jackstands's Avatar
Default Re: Steering and Idle (Chase)
IAC is the more likely culprit but preludes also have a power steering pressure switch. When PS pressure goes up, it tells the ECU to increase idle to compensate for extra load. Clean IAC and clean up the switch too, it's on your pressure metal line. It will be a messy job and you'll lose almost all of your p.s. fluid, but just think of it as a p.s. flush.
Old Dec 6, 2004 | 09:20 AM
yohan's Avatar
Which part is the IAC ? I assume this is on the intake along the PGMFI labelled part between the runners and the injectors ...
How would a person clean this ??
Old Dec 6, 2004 | 09:31 AM
SuperSlow's Avatar
Default Re: Steering and Idle (delguiner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delguiner &raquo;</TD></TR><TR><TD CLASS="quote">IAC valve maybe! try cleaning it!</TD></TR></TABLE>
If not, check alternator output.
Old Dec 6, 2004 | 09:44 AM
yohan's Avatar
what part# ?
Old Dec 6, 2004 | 12:26 PM
ludegetsmwet's Avatar
Default Re: (yohan)
it's #40 if that helps. take it off and clean it with some carb cleaner. it's only two bolts and it shouldn't be a problem. also get a tune up if you haven't had one in a while
Fuzzychaos
Honda Civic (2001 - 2005)
Jun 21, 2015 11:50 AM
ftrms
Mar 31, 2010 07:18 PM
blkb18
Feb 17, 2008 08:18 PM
kornerk12
Feb 17, 2006 10:58 AM
matix
Dec 6, 2003 09:15 AM
