Ticking sound: POSSIBLE BENT VALVE?
Old Dec 5, 2004 | 10:02 PM
Outkast95LS's Avatar
Default Ticking sound: POSSIBLE BENT VALVE?
I read and search a lot of posts about bent valves due to over revving and such. But i have a dilemma myself now. Here's the story:
I finished paying toll and i decided to "mash" on my car a little bit. I ripped it in 1st and i attempted to shift to 2nd, but i misshifted and my RPMs jumped to 7500, and i quickly let off the gas. I drove it all the way to the city until i hit a red light. I heard a loud ticking sound and i assumed it was the car next to me. As soon as i let off 1st, i heard the ticking get louder and knew immediately it was my car. I thought to myself that maybe my belt had came off and its hitting something in my engine bay. I pulled over, and popped my hood and heard the ticking coming from the head area, noticeably near the injectors. Now my question is... Does this sound like the effects of a bent valve or valves?
I checked compression, and it came up 180-185 throughout all 4 cylinders. My car idles fine, and to accelerate fine on the highway (although i havent taken it to redline since the ticking sound). So, if its not bent valves, what else could it be?
Old Dec 5, 2004 | 10:39 PM
Default Re: Ticking sound: POSSIBLE BENT VALVE? (Nine5IntegraLS)
bump, so i can get it fixed and drive my gf!
Old Dec 5, 2004 | 10:41 PM
Slain's Avatar
readjust your valves. do a leakdown test to be sure
thaiphob's Avatar
Nikon!!!
If you were going from 1st to 2nd you didnt really misshift, you just upshifted. it would be misshift if your were like going from like 5th to 3rd
Old Dec 5, 2004 | 10:47 PM
Default Re: Ticking sound: POSSIBLE BENT VALVE? (thaiphob)
Oh oops.. wrong choice of words i guess. Well, regardless, i know misshifting a downshift (like 5th to 2nd) can cause a bent valve because im overrevving like crazy and the rev limiter doesnt help in that situation. But in an event like mine, where im upshifting, and the rev limiter should be in effect, is there a possibility that i bent a valve? Also, what is the stock rev limiter for a 95 LS? I know for a fact i hit 7500 rpms, and then i let off the gas.
Old Dec 5, 2004 | 11:32 PM
.water's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thaiphob &raquo;</TD></TR><TR><TD CLASS="quote">If you were going from 1st to 2nd you didnt really misshift, you just upshifted. it would be misshift if your were like going from like 5th to 3rd </TD></TR></TABLE>
is it bad? going 5th to 3rd? (gsr= was going 60 on 5th..and drop to 3rd..is bad?)
Old Dec 5, 2004 | 11:34 PM
Slain's Avatar
as long as your car is not going past redline.....
Old Dec 6, 2004 | 02:29 AM
s2kkid's Avatar
5th to 3rd isnt that bad, when you from 5th to 3rd you know what your doing, so its not really an error. Ive never had any problems from 5th to 3rd if the rpms are lower in 5th.
What did it for me, was I was wanting to go from 5th to 4th on the interstate at arround 70mph. I went into 2nd... you could smell the rubber from where immediately barked and slowed down.
Needless to say the car went up to arround 9k rpm, It still ran, but immediately after it felt weak, and when youd get off the interstate, it would idle like ****, and barely stay running.
I desided to rebuild my engine(197k), which is in the current half way phase right now, upon disassembly, there was no piston damage, and when the valves were closed it actually looked good... Im sure im in for a supprise when i have the headwork done.
Old Dec 6, 2004 | 10:35 AM
pushinlsteg's Avatar
just readjust your valves, had this happen 3-4 times, misshifting 4th, going into 2nd...the TOP of 3rd gear into 2nd...my stock LS has seen at least 9000-9500...which is not cool. readjust valves, you should be fine
Old Dec 6, 2004 | 12:33 PM
Default Re: Ticking sound: POSSIBLE BENT VALVE? (pushinlsteg)
coo thanks pushinlsteg for the advice.. i will try readjusting my valves
Old Dec 6, 2004 | 01:36 PM
boosted k20's Avatar
yea just do a valve lash on the head. that should fix the ticking. dont think ur valves r bent cuz u got good compression across all cylinders
Old Dec 6, 2004 | 04:29 PM
fxrob's Avatar
Default Re: Ticking sound: POSSIBLE BENT VALVE? (boosted k20)
A stretched out timing belt will cause the valves to tick on a dohc motor also. Depending on how many miles you've got on your engine/timing belt, I'd do a valve adjustment and check your t-belt tension.
Old Dec 6, 2004 | 04:33 PM
Default Re: Ticking sound: POSSIBLE BENT VALVE? (fxrob)
Timing belt was changed within the last 20k miles. Valve adjustment and checkin the t-belt tension will be something i'll do this weekend.
Old Dec 6, 2004 | 04:51 PM
stareatsun's Avatar
Injectors tick also. I have had a ticking, and re-ajusted my valves. Its the injectors because nothing went away after I re-ajusted. Old injectors tick. Its not bad, jstu a sign of wear.
Dav94Lx
Oct 9, 2007 07:53 PM
wragen22
Apr 8, 2005 11:44 AM
iperez
Apr 26, 2004 01:13 AM
Flux
Apr 15, 2004 07:25 PM
DIRep972
May 1, 2003 05:14 PM
