Can a stock B18C1 in an 88' Crx with street tires be able to run 13's in the 1/4m?
Old Dec 5, 2004 | 09:55 PM
GearDownCRX's Avatar
Default Can a stock B18C1 in an 88' Crx with street tires be able to run 13's in the 1/4m?
I'm going to put a gsr motor in my 88' crx and my goal is to run at least 13's. So if it is fairly common to run 13's I won't be worried because I'll be getting a stage 2 clutch and I'm an excellent driver. But if its not common I'll be getting a turbo and boosting low at 8psi. Thanks for any insight
Old Dec 5, 2004 | 10:24 PM
KFBhonda's Avatar
Default Re: Can a stock B18C1 in an 88' Crx with street tires be able to run 13's in the 1/4m? (GearDownCRX)
don't listen to me, b/c i have never driven on track, but...
i do believe that a lightened crx with a good-running b18c1 will break into the 13's if the driver is good.
but i could be wrong...
Old Dec 5, 2004 | 10:27 PM
Jonathan_ED3's Avatar
It can be done.....very attainable!
Old Dec 5, 2004 | 10:36 PM
Rywire's Avatar
Default Re: (Jonathan_ED3)
Mine seems to be able too, but never tried.
Old Dec 5, 2004 | 10:38 PM
Mr_CRX's Avatar
Its definitely do-able with a good driver. Its what I'm hoping for when I go to the next track day.
Old Dec 5, 2004 | 11:35 PM
mengo_charged's Avatar
if its a stock motor, yes with slicks. you can probably do it on street tires but you would need some bolts atleast and having an 88 crx hf would help.
Old Dec 6, 2004 | 04:32 AM
deftones0817's Avatar
Default Re: Can a stock B18C1 in an 88' Crx with street tires be able to run 13's in the 1/4m? (mengo_charge
mine does.
Old Dec 13, 2004 | 02:16 AM
mrspeaker's Avatar
My friend has a gutted only 1 seat and dashboard 88 HF with a stock b18c1/92 gsr tranny..
Hit 13.7????? @98mph on worn azenis..
Hit 13.2??? @ 101mph on Drag radials..
I dont remember the exacts but he suprised the hell outta me..
Its all in the driving..
Old Dec 13, 2004 | 05:40 AM
crxgsr91's Avatar
Yes it is possible.
#1 If you have a really light car
#2 If you are a very good driver
#3 If you run on slicks
#4 If your engine is running 100% and putting out at least 170 at the wheels.
Is it likely.......no
Old Dec 13, 2004 | 07:02 AM
QUiKSR20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgsr91 &raquo;</TD></TR><TR><TD CLASS="quote">Yes it is possible.
Is it likely.......no</TD></TR></TABLE>
So how bout with a perfect running oem motor
intake / 4-1 header / full 2.5 mandrel exhaust no cat
cams, oil pan, full suspension, radius arms, light wheels
intake mani etc?
Im shoooting for mid to high 13s NA ungutted CRX we shall see.
I can drive.
Old Dec 13, 2004 | 07:03 AM
HamiltonRex's Avatar
Gutted HF, stock b16 j1 trans welded diff. Hit 13.0
You have to know how to drive.
Old Dec 13, 2004 | 08:42 AM
turbotommy's Avatar
i think mine will
for sig info!
Old Dec 13, 2004 | 08:49 AM
EL Vap133's Avatar
Take the car to the track and find out...
vader crx
Apr 3, 2013 10:53 AM
JoeG86
May 27, 2005 10:15 PM
lovinthecrx
May 12, 2005 08:16 PM
Mentat Ghola
Sep 7, 2003 11:44 AM
slowstang
Jul 9, 2002 07:13 AM
