Arc welders
Hi, my dad bought an Arc welder a couple of years ago. Its still in the box so i want to put it to good use. I know arc welders arent as good as mig and tig welders, but are there anything i can fab up with it? Such as exhaust system, etc etc. ts got max amperage of 100amps Comments appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tianporn »</TD></TR><TR><TD CLASS="quote">Hi, my dad bought an Arc welder a couple of years ago. Its still in the box so i want to put it to good use. I know arc welders arent as good as mig and tig welders, but are there anything i can fab up with it? Such as exhaust system, etc etc. ts got max amperage of 100amps Comments appreciated.</TD></TR></TABLE>
Plate steel and square tube will be your friends.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tianporn »</TD></TR><TR><TD CLASS="quote">What about round tubing, like exhausts?</TD></TR></TABLE>
You have the amperage to do it with that machine, but you're going to find it , very, very difficult to do, it wasn't meant to do that sort of thing. I haven't seen anyone pull it off. I really just wouldn't waste the metal.
If its a DC arc welder you can convert it to a rudimentary scratch-start TIG welder quite easily (just add a tig torch and gas). Would make a good welder for cheap as long as you don't need AC or high frequency. If all you are doing is mild steel it would probably work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mopar junkie »</TD></TR><TR><TD CLASS="quote">If its a DC arc welder you can convert it to a rudimentary scratch-start TIG welder quite easily (just add a tig torch and gas). Would make a good welder for cheap as long as you don't need AC or high frequency. If all you are doing is mild steel it would probably work.</TD></TR></TABLE>
Would you please elaborate on this a little more? I'm about to buy something, and if I can put together a tig for cheap that would be cool. I saw a Lincoln Ac/Dc welder for about 330 @ HD.
Also I welded my exhaust with a stick welder and it wasn't too bad. used small rods and like 40 amp. Proper speed was critical, though.
I've done about 4 exhausts with sticks! I still dont own anything besides an arc welder. besides the fact I just bought a Clarke 180 but I intend to keep the Arc because its just such a classic art
