gotta headlight question..???
okay..i gotta 97 accord...and my low beams are 9006 and m highs 9005 right?
its kinda a stupid question but i dont know much about lighting...could i purchase 9006s and place em in the high beam socket so i could have them all on...or is the socket fitted to take only 9006?????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cd_5TUNR »</TD></TR><TR><TD CLASS="quote">i guess i could try swappin them then right??? if no one knows...</TD></TR></TABLE>
the high beams are aimed in a different position, and the 9006 bulbs have a covered tip on them. the 9005 dont have any cover. you could do it but you'd have to aim your highbeam section down a lot
You cant just swap 9005 & 9006 w/o some very minor modification, but its super easy. It did work for me on my Integra (which was just stolen) and it was an improvement. I had no need to adjust the beams either. The catch was they did not last very long. About 7 months. Only one of the bulbs blew so perhaps I just had some bad luck.
See my post with pics of the completed conversion and others here.
https://honda-tech.com/zerothread?id=744821
http://www.bmwe34.net/E34main/...t.htm
Modified by mjb240z at 2:47 AM 12/8/2004
Also check out the 9005 conversion...but aiming your headlights helps out a bit
.http://www.bmwe34.net/E34main/...t.htm
AnNiMosSiTY
Sep 9, 2003 11:08 PM
