Damn ABS light.
Old Dec 5, 2004 | 06:39 PM
DC2-JRSC'd's Avatar
Default Damn ABS light.
When i replaced my rear shocks i had to cut the abs lines in the rear to get the shocks/lca's out. Now i put them back and the abs light is still on. I tried to get the codes but all i get is 3 flashes. I checked the code list but thats not a code. Does anybody know whats wrong with them?
Old Dec 5, 2004 | 06:51 PM
T S R Performance's Avatar
Default Re: Damn ABS light. (dan4g63)
have you tried resetting your battery just in case?
Old Dec 5, 2004 | 08:29 PM
DC2-JRSC'd's Avatar
Default Re: Damn ABS light. (T S R Performance)
yes i have
Old Dec 5, 2004 | 08:32 PM
SiR Inspired ED7's Avatar
that sucks, i bet u did not disconnect ur battery b4 working on ur car...
Old Dec 8, 2004 | 07:28 AM
DC2-JRSC'd's Avatar
Default Re: Damn ABS light. (92 DA B16a)
no i did not. any other ideas?
Old Dec 10, 2004 | 07:04 PM
black90si's Avatar
Take the bulb out.
Old Dec 10, 2004 | 07:18 PM
Bay_707's Avatar
Default Re: Damn ABS light. (black90si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by black90si &raquo;</TD></TR><TR><TD CLASS="quote">Take the bulb out.</TD></TR></TABLE>
lol
Old Dec 10, 2004 | 07:38 PM
DC2-JRSC'd's Avatar
Default Re: Damn ABS light. (Bay_707)
well its not the light thats bugging me, i want my abs to work.
Old Dec 10, 2004 | 07:52 PM
LS-lownslow's Avatar
same here... i bought my car with the light on and i cant figure anything out to fix it ....
Old Dec 13, 2004 | 04:18 AM
Hyperazn18's Avatar
Default Re: (LS-lownslow)
i put on five lug on the rear of my da. put on the lines and they dont work!!
Old Dec 13, 2004 | 06:28 AM
WhatThaFrig's Avatar
Default Re: (Hyperazn18)
Have you looked here?
https://honda-tech.com/zerothread?id=978933
Old Dec 13, 2004 | 06:52 AM
sleevedgsr's Avatar
Try calling technical support. Redo the whole process but this time take off the battery and replace the bulb.
Old Dec 13, 2004 | 07:40 AM
DC2-JRSC'd's Avatar
Default Re: Damn ABS light. (boosted95teg)
what does "ABS pump motor over-run" mean?
Old Dec 13, 2004 | 11:29 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dan4g63 &raquo;</TD></TR><TR><TD CLASS="quote">what does "ABS pump motor over-run" mean?</TD></TR></TABLE>It means when you start the engine, the ABS motor runs for more than ??? seconds. (I forget the limit.) Could be several different things...
- Air in the ABS brake fluid.
- Pressure switch is bad or disconnected.
- Pump is bad.
- Accumulator is leaking, internally or externally.
Blaze45
Mar 12, 2013 02:59 PM
Type_R_Lover
Nov 7, 2006 09:10 AM
V-Thang
Jun 21, 2004 10:56 AM
BigChris
Jun 13, 2004 09:42 PM
RyanAutry
May 3, 2003 02:23 PM
