why is my motor burning oil?
DO a compression test and see what you get. Add a squirt or 2 of oil to each cylinder. If the compression goes up you might still have bad rings. If it doesn't go up and you changed you valve stem seals then I am not sure.
my first oil change at 1k. i changed the oil and i check the oil weekly cause im scared that i might not tighten the nut tight enough so oil might leak out. anyways i still noticed that it is still burning oil. i've added 3 quarts of oil so far and need about another 1500 miles to do the next oil change (the usual 3k oil change). i just check the oil again today and it is at where the bottom hole on the dipstick is at. i don't know if this helps but i use castrol 10w 30
just to reassure you, break-in period on a motor can be as long as 6000km (don't know in miles, roughly 4000) so just be patient and check your oil often.
Is this a stock or performance rebuild? If you made damage to the motor, it was probably before 500 miles. Was it tuned from the start?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mart_It »</TD></TR><TR><TD CLASS="quote">just to reassure you, break-in period on a motor can be as long as 6000km (don't know in miles, roughly 4000) so just be patient and check your oil often. </TD></TR></TABLE>
damn i'll just check on it till it goes away
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ti3d in »</TD></TR><TR><TD CLASS="quote">Is this a stock or performance rebuild? If you made damage to the motor, it was probably before 500 miles. Was it tuned from the start?</TD></TR></TABLE>
its pretty much stock. i rebuild this and it is in my ek so i can drive to skool and stuff like that. i'm THINKING bout building another gsr so i can turbo it and sell the one i have right now.
kobeballer96
27
May 1, 2009 01:13 AM
