Turbo lude
Old Dec 5, 2004 | 04:20 PM
Turbokid13's Avatar
Default Turbo lude
anyone kno the safe boost to run on stock lude internals
Old Dec 5, 2004 | 04:22 PM
redlude04's Avatar
Default Re: Turbo lude (Turbokid13)
I would say 7-9 no more than that.
Old Dec 5, 2004 | 04:49 PM
ludegetsmwet's Avatar
Default Re: Turbo lude (redlude04)
i would say about the same as long as it is properly tuned and has the right a/f mixture. tune it right and shouldn't have problems
Old Dec 5, 2004 | 05:18 PM
md23vtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbokid13 &raquo;</TD></TR><TR><TD CLASS="quote">anyone kno the safe boost to run on stock lude internals
Its all in the tune. Westfinkter huh I hope you have good tuner, I know of plenty of people blowing up ludes in MD goodluck
Old Dec 7, 2004 | 10:54 AM
PrettyLude's Avatar
7psi i even blew ringlands at that much psi
Old Dec 7, 2004 | 01:09 PM
preludeez's Avatar
Default Re: (PrettyLude)
i think you should be safe at 6psi and tuned.
Old Dec 7, 2004 | 03:15 PM
5hif7's Avatar
SEARCH
Old Dec 7, 2004 | 03:25 PM
Boost Addict's Avatar
Default Re: Turbo lude (5hif7)
A lot of info here: https://honda-tech.com/zerothread?id=316373
Old Dec 7, 2004 | 03:46 PM
TonyTurbolude's Avatar
1000psi on stock internals should get u near 1000hp and 500tq
Old Dec 7, 2004 | 07:04 PM
PrettyLude's Avatar
funny
Old Dec 7, 2004 | 08:07 PM
prylwd's Avatar
7psi or less. IMO this is not somthing to push to the limit, also make sure it is tunned.
killa_lude's Avatar
The boost isn't the issue, it depends on the flowrate of the turbo and how good the car is tuned.
Old Dec 7, 2004 | 08:44 PM
fastludeh22's Avatar
Default Re: Turbo lude (killa_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude &raquo;</TD></TR><TR><TD CLASS="quote">The boost isn't the issue, it depends on the flowrate of the turbo and how good the car is tuned. </TD></TR></TABLE>
exactly... i see too often people asking this question and everyone responds w/these arbitrary #'s. i mean these are all in the common range, but there a lot of factors. turbo size is a big one, but not the only. the whole efficiency of the system. type of use, condition of engine, TUNE, how long do you want tit to last, and a whole lot more...
for reference only, i ran 10#'s on a 60-1 for 8 months, daily getting on it, hit 12-13 #'s a few times. GREAT tuning and fuel system is what kept mine alive. there are others doing the same, but we are not the norm....as you will hear more then you want research
Old Dec 7, 2004 | 11:46 PM
aboh6leenz's Avatar
Default Re: Turbo lude (fastludeh22)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastludeh22 &raquo;</TD></TR><TR><TD CLASS="quote">exactly... i see too often people asking this question and everyone responds w/these arbitrary #'s. i mean these are all in the common range, but there a lot of factors. turbo size is a big one, but not the only. the whole efficiency of the system. type of use, condition of engine, TUNE, how long do you want tit to last, and a whole lot more...</TD></TR></TABLE>
hehehe But where are you located fastludeh22
i'll say go with 5 psi, boost is boost.
Old Dec 8, 2004 | 09:18 AM
Boost3d22's Avatar
Default Re: Turbo lude (aboh6leenz)
my ignition relay failed at 9psi and i blew 2 pistons soo yea make sure your car dosent lean out and is tuned correctly.. run like 5-7psi
beaversdc5
14
Oct 29, 2007 05:29 PM
M7EG6
35
Sep 25, 2007 07:25 PM
vtak2nr
Jan 13, 2007 11:10 AM
95teg_ls
Nov 16, 2006 02:32 PM
snzh22
Nov 6, 2006 01:20 PM
