88 CRX Si Brakes ????? How To Remove Brake Booster, MC ?????
Old Dec 5, 2004 | 12:42 PM
The DX Rex's Avatar
Default 88 CRX Si Brakes ????? How To Remove Brake Booster, MC ?????
basically my brakes on my crx si are mad f*cked up and a couple of people looked at it and said it has to be my brake booster.
so im just going to the junkyard and going to pull a brake booster and master cylinder.
my question is how difficult is it to take both of them off. the master cylinder looks like it is jus 2 bolts and unhooking some lines, how do you get the brake booster off??????
Old Dec 5, 2004 | 12:55 PM
The DX Rex's Avatar
Default Re: 88 CRX Si Brakes ????? How To Remove Brake Booster, MC ????? (nyhustla2k)
bump
Old Dec 5, 2004 | 01:12 PM
The DX Rex's Avatar
Anyone?
Old Dec 5, 2004 | 01:26 PM
eda6's Avatar
You have to remove the pedal to booster pin. Then remove the firewall to booster nuts.
Unfortunately all this is under the dash.
I'd make sure the check valve between the booster and intake manifold was working before i took anything apart. Remove the vacuum hose from the booster there should be vacuum.
Old Dec 5, 2004 | 01:33 PM
The DX Rex's Avatar
Default Re: 88 CRX Si Brakes ????? How To Remove Brake Booster, MC ????? (eda6)
another thing, when i am in nuetral and press down on the brakes my rpms jump from 500-800 to 1500-2000 rpms, only when i push down on the brakes
Old Dec 5, 2004 | 02:25 PM
The DX Rex's Avatar
Bump anyone?
Old Dec 5, 2004 | 03:01 PM
MattP's Avatar
Part of the same problem. You're drawing in more air through the brake booster, due to a bad diaphram or other problem in the booster.
Old Dec 5, 2004 | 03:42 PM
The DX Rex's Avatar
Default Re: 88 CRX Si Brakes ????? How To Remove Brake Booster, MC ????? (MattP)
bad diaphram? whats that?
so its prob. is the brake booster then righT?
Old Dec 5, 2004 | 07:00 PM
The DX Rex's Avatar
bump
Old Jun 24, 2011 | 04:45 PM
cheeesboiger's Avatar
Originally Posted by The DX Rex
bump
hey its your brake booster, just replace it with one of another civic. i'm using one from a 94 civic, no increase in stopping power. anyway, removing the pin and cotter pin are relatively easy compared to the four 12mm nuts you have to remove. EVERYTHING is in the way, at least for me. all i have is a 3/8 drive ratchet, and a couple of 12mm sockets with a 3" extension. i've been at it for almost 3 hrs with breaks in between and i've only removed 2 of the 12mm nuts! i need help.
Old Jun 24, 2011 | 05:26 PM
1990edsedan's Avatar
Dude...did you not look at the post date? - 2004!
Old Oct 30, 2013 | 05:33 PM
tonekids's Avatar
And yet here I am, almost three years after your post, finding this to be useful information!
Old Oct 30, 2013 | 08:37 PM
Riceburner247's Avatar
You don't need to bump a thread for it to be useful is the point.
Old Nov 4, 2013 | 05:06 AM
tonekids's Avatar
Right, but I wouldn't consider that post to be a bump. It was relevant, if a bit dated.
trailblazer
Aug 23, 2016 07:16 AM
SlammedEG6
Aug 16, 2010 12:46 PM
Spikey640
May 18, 2008 09:09 AM
b16_madman
May 25, 2003 11:52 AM
magbarn
May 22, 2003 03:28 PM
