People with stock CR-X Si crossmember and DC header
I need some info on what you guys did so that the header runner Dosent touch the crossmember. What tools did you guys use to mod the crossmember. I know that buying a full-race crossmember would be the easiest option, but Iam a lil bit tight on my budget right now
TIA.
TIA.
Mine installed just fine, with a good 2-3" clearance.
It drops right in, even with the A/C and fans in.
is the bottom section hitting the CM?
Do you have a stock cat, and exhuast?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16 ED9 »</TD></TR><TR><TD CLASS="quote"> What tools did you guys use to mod the crossmember.
A big *** hammer..
A big *** hammer..
See here is the thing, when I was installing the motor I put in the Dc header, after turning on the car there was lots of smoke filled up in my parking lot. When I took a look at the header it looked like that the down pipe was touching the CM just a lil bit. Or I might bee wrong cuz there was finger prints and grease on the header, It might of been burning of while the car was on
Yah I have stock cat and a stock exaust as of righ now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16 ED9 »</TD></TR><TR><TD CLASS="quote">What tools did you guys use to mod the crossmember.</TD></TR></TABLE>
Makita grinder, lincoln welding sticks, oxy/acetylene torch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mrspeaker »</TD></TR><TR><TD CLASS="quote">A big *** hammer..
I used a big *** hammer and a grinding wheel.
cal_gecko
May 6, 2006 12:23 AM
