Cams + Nos = bad???? You tell me!
I got a 97 prelude base w/ all basic bolt-ons and goin to spray a 50-75 wet shot. Im probably goin to go stg 2 with valves, springs and ret. I hear stuff bout nos and cams that are slowing me down please help me out thxs
When you buy cams, you are going to want to make sure they are the best for your setup. If your case, you need to find cams that work well with forced induction.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boost Addict »</TD></TR><TR><TD CLASS="quote">When you buy cams, you are going to want to make sure they are the best for your setup. If your case, you need to find cams that work well with forced induction.</TD></TR></TABLE>
Well, the best cams for forced induction are usually stock cams...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmcivicferio »</TD></TR><TR><TD CLASS="quote">not true, for Turbo stock cams are best, for nitrous, allmotor cams will work excellent.
i'd agree since that which nitrous you still have the same amount of air coming in.
</TD></TR></TABLE>i'd agree since that which nitrous you still have the same amount of air coming in.
I second that
</TD></TR></TABLE>I second that
From: united states of mexico and yes ladies i am, available
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 »</TD></TR><TR><TD CLASS="quote">
Well, the best cams for forced induction are usually stock cams...</TD></TR></TABLE>
so turbo cams on a turbo set up dont work as good as stock?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 »</TD></TR><TR><TD CLASS="quote">nahh turbo cams will work well with a turbo car....but not all motor cams</TD></TR></TABLE>
Stock cams are perfect for turbo
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 lude »</TD></TR><TR><TD CLASS="quote">N/A cams and notrous =
Looks like you've been sniffin a little too much of the giggle gas Chris!
</TD></TR></TABLE>Looks like you've been sniffin a little too much of the giggle gas Chris!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raylude »</TD></TR><TR><TD CLASS="quote">
so turbo cams on a turbo set up dont work as good as stock?</TD></TR></TABLE>
no, turbo cams on a turbo set up will work better than stock cams on a turbo setup, however stock cams work very well on turbo set ups up til around 400whpish so cam upgrade for boost isnt necessary until u are at that point
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Evil Nick M »</TD></TR><TR><TD CLASS="quote">cams arent as big of a concern as compression and tuning is</TD></TR></TABLE>
And if you really wanna get into it, big n/a cams can actually help drop dynamic compression in the big lobes, helping to keep you avoid detonation a little more.
Sorry to hijack the thread, but are there any cams that work well with a supercharger? Or would I just use turbo cams? What sort of duration and lift would I need?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign »</TD></TR><TR><TD CLASS="quote">
no, turbo cams on a turbo set up will work better than stock cams on a turbo setup, however stock cams work very well on turbo set ups up til around 400whpish so cam upgrade for boost isnt necessary until u are at that point</TD></TR></TABLE>
That is totally false
. There are 700HP plus b seriers on stock cams. I know of prelude in VA thats my buddy Jason tuned and made 534whp with stock cams. I can get my hands on crower turbo cams fairly cheep but Jason Hunt says its a waste of money, plus few other big names say use the money else where. Just my 2cents
From the book "Maximum Boost"
"Make no mistake in the fact that turbo performance cams are very different from atmospheric performance cams. The characteristics of long duration and high overlap for atmo cams are unwelcome in a turbo system. The street turbo, which is generally small, operates with exhaust manifold pressure somewhat higher than intake boost pressure. This situation, when presented with long duration, high overlap cams, creates a huge amount of reversion. Thus the "turbo cam" tends to become a low-duration, very limited overlap cam"
You do not want overlap with a boosted engine because the of exhaust gas reversion, and most NA cams have a decent amount of overlap...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hOndafienD 04 »</TD></TR><TR><TD CLASS="quote">im sure you would be able to push a loit more out of those motors with some nice big fat cams, and you would see an power improvement over stock.</TD></TR></TABLE>
ummm.....not on a turbo motor dude, those fat *** lobes will leak all your boost out during overlap....good turbo cams are little weenies!
It turned into a boost cams discussion because you would use the same type of cams for a nitrous application as you would for a turboed car since you're pushing more air into the engine in both cases
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRCLude98 »</TD></TR><TR><TD CLASS="quote">It turned into a boost cams discussion because you would use the same type of cams for a nitrous application as you would for a turboed car since you're pushing more air into the engine in both cases
Er, you're just injecting a chemical with a greater % of oxygen than regular old air...
</TD></TR></TABLE>Er, you're just injecting a chemical with a greater % of oxygen than regular old air...
no you arent......nitrous makes gasoline more volatile....no more air than usual is in there......
boy some of the stuff people say.....
</TD></TR></TABLE>no you arent......nitrous makes gasoline more volatile....no more air than usual is in there......
A LOT of misinformation being thrown around in this thread.
Turbos and other FI options want more lift which cams can give. However, at the same time they want a reduction in overlap to prevent blowby. That being said the Skunk2 stage 2 cams CAN work very well for turbo's with their relatively low duration times. If you need less overlap you can tune that out with cam gears.
Nitrous can be very tricky with cams due to the fact that you're introducing a turbulent flow into the air stream by injecting nitrous/fuel into the intake stream. But generally you treat it like you would a N/A project. Scavenging effects are virtually the same it's more the tuning that you have to watch out for on these.
