HX operating ?
Guest
Posts: n/a
Does the HX setup run on 2 valves before vtec is activated and once it kicks in then it works on 4 valves or the other way around? If it works on once vtec hit it opens 4 valves how can I make it constantly keep it in vtec? I'm asking this since I don't wanna use the HX ecu cause that **** is rocket science within itself and plus I'd have to switch over to OBD2 which I'd never do just to use that shitty non chipable ecu. I was thinking of using uberdata to operate this head and make it run properly without using that ecu. help anyone? I wanna try use this head out on my 1.5 NA setup I'm building. If the head runs 4 valves when vtec is on how could I stay in constant vtec?
Modified by egizzle6 at 12:02 PM 12/5/2004
same ol' civic
Apr 2, 2003 10:29 AM
