Running Loose on bearings for a turbocharged b18c?
I was having my machine work done and the shop was just asking what all i was putting in it,
They were talking about I may want to run a little loose on the bearings, not too much, but a little play.
They told me I might want to ask and see what others have done.
I did not cut my crank, I had it balanced and micropolished(Journals are pefect) The crank had 197K miles when pulled.(was not knocking either btw)
So Question is, Do you think I should go back with the stock color since its been micropolished, and had miles, and achieve a little play without knocking.
I dont like the idea of going with a different color, but I figured since this has work been done, I dont need to.. That Ill achieve that tiny bit of play with what bearings it calls for.
Furthermore, This motor is gonna be ran N/A for a few months, untill after breakin, and When I purchase the parts to install...
Any comments?
Any comments?
My only suggestion is that you is that you should measure the bearing oil clearances instead of guessing.
hmtcrxsir
Apr 14, 2009 08:15 PM
